Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-31-2004, 01:41 AM
Toke138 Toke138 is offline
Send a message via AIM to Toke138
b16a into 5th gen civic
After my timing belt snapped I thought it might be a good time to get that motor swap done I've been planning.
I havent bought anything yet and I need to get my car moving again as soon and as cheap as possible with the exception of it not being another d16z6. My car is a 94 civic ex 2 door automatic, I want to change over to a standard but I can get a b series automatic tranny for free so I'm gonna stay automatic for the time being.
My questions are...
Which b16a will take the least effort to drop into a 94 civic?
Will I have to alter/change axles to use a tranny from a b21a1?
Will the b16a exaust manifold bolt into and line up with the stock exaust?
Old 06-01-2004, 12:31 PM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Re: b16a into 5th gen civic
since you have the automatic tranny the b16a1 and the b16a2 will take the least effort to drop in.
what's a b21a1?
b series parts are not interchangeable with d series parts.
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-01-2004, 03:09 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: b16a into 5th gen civic
what's a b21a1?
Stop speaking.
1. 92-95 B16A is the best for you, you don't want to use a OBD 0 B16A(1) because you'll have to change a few things (distributor, injectors, various sensors), and wind up spending the same anyway.
This guy has one he is selling (B series auto tranny), good guy too, it's from a 90-91 so the plugs maybe different.
http://www.hondaswap.com/forums/inde...0&#entry367147
2. The B21A1 is the old Prelude motor right? Can't use it, not the same B family, plus it's probably a POS anyway. You can either source your own auto tranny, or get a B16A auto from an importer. IMO you'd be better off getting an auto GSR for a little more.
3. Yes it will bolt up, but if you have a model withbthe cat right off the motor, you are going to have a space about 1.5' between it and hte B pipe.
Old 06-01-2004, 06:06 PM
Re: Re: Re: b16a into 5th gen civic
that is a b20a
Old 06-01-2004, 06:09 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
B21a1 is an early '90 something Prelude motor
Old 06-01-2004, 10:34 PM
Re: Re: Re: Re: b16a into 5th gen civic
that is a b20a
Like I said, stop speaking, it's from the 90-91 Prelude Si.
Old 06-02-2004, 12:09 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
isn't the b21a1 carbeurated? or is that the years before that one
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 06-02-2004, 12:13 AM
Fuel injected y0!!! B20A3 had dual side drafts.
Old 06-02-2004, 12:15 AM
DeleriousZ's Avatar
i see.. any idea what the code is for the carb'd lude? it's gotta be pre-87 right? my buddie's got one, it's crazy stuff
Old 06-02-2004, 12:20 AM
ES, and the B20A in Japan, A18A1 (carbed) in the US 87, also EK1, ES1, and EF1 depending on how far back you go.
Old 06-02-2004, 08:12 PM
b21a1 is from the 90-91 prelude si, it is fuel injected
If i get the tranny that was designed for the sir2 b16a I should have no axle problems, correct?
I read somewhere that I will have problems with using JDM injectors with my USDM ECU, is this correct? If so what is the best course of action for me to take?
Old 06-02-2004, 08:15 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
All i gotta say is...
..stay the hell away from the prelude b-series
Old 06-02-2004, 11:53 PM
Exactly. It is a FAR cry from the Civic/Sol/Teg B series motors, and don't let anyone tell you it's not. Yes it says B on it, but it is more the alcoholic, dysfunctional uncle of the family.
Old 06-06-2004, 01:35 AM
I was told that I need axles from an integra and a custom mount for the automatic tranny, is this true?
Old 06-06-2004, 12:02 PM
If you aren't changing from auto to manual, no you don't.
