Old 05-11-2004, 10:57 PM
Renegade's Avatar
Renegade Renegade is offline
Send a message via MSN to Renegade
Testors clear coat over Automotive Paint?
Hi again
I'm thinking of painting drivetrain with the same color as body (Automotive spray paint). But I don't like that shiny look so I would clear coat with Testors dull(flat) lack. Can I do this? I guess If I can paint enamels over automotive spray paint I can also clear coat with Testors flat coat?
Tnx!
Old 05-11-2004, 11:19 PM
Renegade's Avatar
Re: Testors clear coat over Automotive Paint?
Darn. I will be using DupliColor as usual. I guess that's acrylic laquear.
And what is with Tamiya spray paint and Testors clear coat?
I was also checking this table (bottom page):
http://www.tamiya.com/english/scale/beginner2/2.htm
Can come handy to someone
Old 05-11-2004, 11:23 PM
Renegade's Avatar
OK, thanks!
I will also test paint on some plain styrene to check it before painting the model.
Old 05-12-2004, 08:42 AM
tonioseven's Avatar
Originally Posted by Renegade
Hi again
Tnx!
You can use Testors clear over the auto paint, just no auto paint over the Testors.
Old 05-12-2004, 08:56 AM
phase5's Avatar
phase5 phase5 is offline
i always use Tamiya x-22 clear over enamels and laquears and i have also used enamel clears over acrylics as well with no problems. but no laquear clear over acrylic or enamels it eats into them.
and when i want a dull coat i add flat base from Tamiya to the x-22 and you get a flat base
glue glue and more glue
www.djamos69.com
Old 05-12-2004, 09:19 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Testors clear sucks...If your going for durable paint you need to use automotive paint through out from the same brand, as well as the same type (i.e. acrylic laquer)
-Mike
Old 05-12-2004, 11:08 AM
Renegade's Avatar
Interesting. You all say that Testors clear sucks. But my friend who makes scale model airplanes said Testors-ModelMaster makes the one and only Clear for him. He's using flat.
So, basicly I can paint enamel over automotive. But I shouldn't use lacquear over enamel - sadly I don't have a pic from a few month ago when I was clearcoating enamel paint with automotive lacquear. The enamel got all soft and cracked and start crazin'.
Thanks guys!
Old 05-12-2004, 03:58 PM
mike@af's Avatar
The reason why he likes their clear coats is because he only uses dullcote. Testors Glosscote is basically dull coat.
As far as coverage types. Enamel on enamel, acrylic on acrylic, laquer or laquer, and so on.
-Mike
Old 05-12-2004, 04:06 PM
Vric's Avatar
Vric Vric is offline
Testor clear # 18xx is ok.. but it get yellowish with time.. Just look my Enzon in my gallery.
Old 05-12-2004, 04:09 PM
Renegade's Avatar
Great GTMike! Thanks 100 times
And yes, he's only using dull coat.
And just one more
How good is Tamiya enamel compared to Testors-ModelMaster enamels?
For clear coats I'll order Tamiya X-22 - thanks to Phase5
Old 05-12-2004, 04:17 PM
mike@af's Avatar
Havent toyed with the Tamiya enamel, I usually steer clear of enamels. I always paint using Acrylic Urethane, Acrylic Laquer, or just basic Acrylic.
I have used MM enamels though. I find them pretty nice. They are the caviar of Testors.
-Mike
Old 05-12-2004, 04:20 PM
supermod04's Avatar
supermod04 supermod04 is offline
Banned
Send a message via AIM to supermod04 Send a message via MSN to supermod04
tamiya makes nice paints. i have used enamal alot, and acrylic laquer. the only testor products i use are their jar paints, and i use them in ym iarbrush and for detailing. i have heard good things from tamiya, i havent used it becuase i have yet to see tamiya in jars for airbrush.
Old 05-12-2004, 04:40 PM
tonioseven's Avatar
I've had excellent results with Testor's #2936 Clear spray. May be just me though.
Old 05-12-2004, 05:40 PM
mike@af's Avatar
Re: Re: Testors clear coat over Automotive Paint?
Tamiya's main line of paint is in jars. How the hell cant you find them?
-Mike
Old 05-12-2004, 05:51 PM
D.J.'s Avatar
D.J. D.J. is offline
Re: Re: Re: Testors clear coat over Automotive Paint?
We dont even have tamiya in our country
