clutch adjustment need help
i need to adjust my clutch but cant figure it out,i found the adjuster nut and tried that didnt help, the clutch seems to be not as tight as it should be. If anyone has any info for me that would be much appreciated
Re: clutch adjustment need help
As American As A Burrito! USDM 4 life! |
On the topic of adjusting clutches, which way should I turn it if my clutch enguages (meaning I am releasing the pedal) too soon and it's hard to get it into gear? It seems to take more effort than it should to put it in gear, too much resistance. I think this is due to the fact that my clutch is engaugeing too soon or that it doesn't fully disengauge.
![]() "us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat |
Re: Re: clutch adjustment need help
Re: Re: Re: clutch adjustment need help
turn the adjustment (near the battery) counter-clockwise...i had the same problem, you should feel it get looser, if that makes it worse go the other way.
Righty Tighty,
Lefty Loosey. If its really tight, then once you put it in gear and let off the clutch, the car with jump into gear. Making it really loose gives it a slower reaction. When I bought my CRX, it was soo tight that once I put it in 1st, it literally jumped 10 feet in a second. I hope this helps you out.
89 CRX Si B16 | BW Body kit | 17" 8 Spoke | Airbagged
i already adjusted the cable,no diff,so I should adjust the adjusting bolt? Is it just above the pedal inside the car?
