My rear brake lights both went out at the same time. Replaced bulbs but did not help. High mounted brake light in window still works but that's it.
Anyone encounter this problem? |
Had the exact same problem. The problem is that the switch has a short and needs to be replaced. The REAL problem is that the switch is in your steering column (believe it or not) and the entire turn signal switch will need to be replaced!
The switch runs about $100, labor about 2 hours, so figure $130 or so. Good luck! |
Re: 1995 Lumina Brake Lights won
Thanks for the reply, it is much appreciated. I'll have my trusted mechanic check that out.
Did this fix the problem?? is the brake switch inside the steering column or above it?? is it part of the blinker assembly? how much did it cost to repair??
Re: Re: 1995 Lumina Brake Lights won
Yes, it fixed the problem. However, my mechanic charged me $180 to fix it. It was the switch in the steering column. Brake lights and turn signals work fine now.
Seems a bit expensive, but my peace of mind was worth it. I didn't like driving without brake lights and scanning for police cars to make sure they didn't pull up behind me and notice my brake lights out. |
