Go Back   Automotive Forums .com Car Chat > Honda > Prelude
Old 04-20-2004, 11:12 PM   #1
Ziggymidget5
Send a message via AIM to Ziggymidget5
Running a richer fuel mixture
A was just thinking about how to extract N/A power through bolt-ons today, and i was wondering if a Apex-i Safc, JET chip, or Hondata (i can't get a Vafc because i have an H23A) and an upgraded ignition would alone allow me to run a richer mixture. I already have a CAI and Exhaust to help airflow. And while we are on ignitions, i was curious as to what advantages advancing the ignition timing has (if any), just enough so it doesn't ping. Thanks for your help, i know that i like asking questions.
White 1995 Prelude Si 5-speed 107,000 miles
AEM CAI
AEM Pulleys
DC Sports CC Header
Carsound Hi-flow Cat
5Zigen Fireball Cat-back
17" wheels with 215/40/17 tires
Custom paint on some interior (yellow)
Currently in Progress:
KMS (Honda-performance.com) Camshafts, Valve springs, and Retainers
Skunk2 adjustable cam gears
Wish me luck on this project, something always seems to go wrong.
My 1995 Prelude Si
Ziggymidget5 is offline   Reply With Quote
Old 04-21-2004, 02:37 AM   #2
crzyCollegeKid
Re: Running a richer fuel mixture
generally, from what i have heard, those chips will increase your power output to a certain point depending on the mods you have. purposely running a richer fuel mixture on a relatively unmodified engine is pointless and probably dangerous since honda engines usually run a lil rich stock to protect them at the higher rpm's.
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
crzyCollegeKid is offline   Reply With Quote
Old 04-21-2004, 12:44 PM   #3
AcesHigh
Prelude Guy
AcesHigh's Avatar
Send a message via AIM to AcesHigh
Your stock ignition system does not have to be upgraded, nor will you get anything out of upgrading it. You want to upgrade your fuel management system if you are to buy an SAFCII(stay away from chips...). The p14 ecu found in Prelude Si's are not Hondata compatible. You'd have to use a p28 or p72 ecu, and that requires alot of expertise in tuning.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
AcesHigh is offline   Reply With Quote
