Go Back   Automotive Forums Car Chat > Chevrolet > S-10
Old 01-13-2004, 03:31 PM
TopDogg TopDogg is offline
Help lifting a Jimmy 4x4 front
I need the best yet cheapest way to lift a Jimmy/Blazer 4x4 front end 2 inches. 2.5 if possible. I have only had experience with solid front axles until this truck.
Old 01-14-2004, 11:45 AM
Fox_Rocks Fox_Rocks is offline
Re: Help lifting a Jimmy 4x4 front
take and crank up the torsion bars, there is a bolt that goes into a cam on the end of the torsion bar, if you crank it in, it will lift it. The bolt is located in the crossmember that the torsion bar rests in. But be forwarned that if you do that it will change your camber adjustment and you will badly need an alignment, the tires will look like this \-/ when your done. The only other way is to buy a lift kit for it, it gives you different spindles and a dropped crossmember. Not really worth it. Hope that helped, and if you look in the picture below you will see the 2" of lift i got out of it, i still have probly 1" or so of lift left in the bolts.
1991 Chevy S-10 Ext. Cab
4X4, 4.3L TBI V6.
-Competition Camshaft, Ported Heads, Bored .40 Over,
Completely Rebuilt (everything), Roller Lifters, K&N Filter,
MSD Wires, Jet Performance Chip, B&M Shift Kit,
AirRaid TBI Spacer, 3:42 Posi Trac, 2" Lift,
American Racing Wheels, BFG All Terrain Tires
Old 04-20-2004, 05:43 PM
sspence sspence is offline
lifted s10
topdog: did you try the suggestion?: crank in the torsion bar, then get an alignment? I'd like to try to get 2" on the front of my '98 S10 4x4. Wondered if it worked.
sspence
01 jimmy 4x4 front wheel hubs chobes Jimmy 2 12-04-2010 12:43 PM
Jimmy 4x4 conversion rglsaenz Jimmy 1 07-21-2010 06:52 PM
Selling or Parting 93 jimmy 4x4 4.3 Votec(w) ibceng Classifieds 1 10-08-2009 04:34 PM
1991 s15 jimmy 4x4 front wheel bearing and axle rickey446 Jimmy 0 12-20-2005 10:02 AM
95 Jimmy 4x4 front shock installation mckenzi Jimmy 4 03-22-2005 11:13 PM
