My GEO stoped running for me while i was driving down the road. I pulled it home and started working on it. I have fuel and preassure to the injector, I have spark and I have compresion. If I spray starting fluid into the throtle body the engine will run.I have hot wired the injector and it does spray fuel till it is out of fuel preasure so i figure that the injector is in working order. I have checked all the fuses and the relays,the injector resistor and replaced the crankshaft postiton sensor. I think that the cam sensor is fine because the thing runs with starting fluid, I assume that the ignition modual is good for the same reason.Maybe my ECM went bad ????????
Can anyone help me ?( PLEASE ) Thanks chevy383 |
i would say that if the plugs fire that the ecm is good. metros are notorious for being very sensitive to a worn timing belt. the belt can appear to not be worn, but if it has streatched longer and ofsets the cam by as little as 3 degrees, then the engine will not start, but the starting fluid has more power than regular gasoline fuel and will run the engine. try changing the belt. a hint on that.... unless you want to pull the engine, you will have to make a slit in the bottom of the timing cover with a razor knife so that you can pull it off and see the timing marks. the timing marks are 4 spurs sticking out of the crankshaft behind the main pulley and then a mark on the cam sprocket will line up with a grove on the valve cover.
Re: 97 GEO Metro wont run ( HELP )
check the fuel pump pressure
Thanks,but I am still lost
I have about 27 lbs. of fuel preasure and when i hot wire the injector to the battery with a fuse and a switch i can flip the switch on and off very quickly and the injector sprays fuel and the ingine will run for me ( allthough no very well ).
I put a new timing belt on about 12k miles ago when i rebuilt the engine. There is a small unit atatched with two screws to the fire wall to the right of the coil as you are looking at the coil, it says POWER UNIT. I can not find this in my manual. What is it for, and could this thing be my problem? Thanks chevy383 |
![]() Join Date: Jul 2003
The power unit controls the signal between the ECU and the ignition coil. Keeping it a safe voltage for the ECU to control the ignition. If you get spark, the firing unit(power unit) is fine.
![]() Join Date: Feb 2004
Ok, never having had any ignition grief with these things.. ( other than being retarded and thats me, not the ignition ) Do not rule out the ign module. On the vast majority of FI engines, the injector pulse is controlled by a reference voltage from the ign module. This tell the ecm when to pulse the injector. So, this could be your problem. you can still have spark enough to set you on your butt, but no actual fuel delivery. Check it out
#7 | |
Thanks for all the good info guys.Iam trying everything,this thing should be runnung.I have today ordered the GM shop manual for my beloved GEO. I will trach this thing down.If anyone comes up with something else to try please let me know.
Thanks chevy383 |
#8 | |
Hey Guys, I am a very happy camper!!!!!!
I got my service manual and it said that the injector resistor olms should be between 1.8 and 2.9 and mine was 14.3...... I got a new resistor and it live to die another day.. I am happy... Thank you everyone |
