Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-13-2004, 02:05 PM
yakez yakez is offline
Starting my Aurora
Here's the deal, my 95 Aurora always starts, however 95% of the time it takes about anywhere from 2-4 seconds to actually start. When I turn the ignition it just continues to turn over until the vehicle starts. Only a handful of times it starts normally, sometimes when it is very cold outside or after I have been driving it for sometime. There does not seem to be any consistency in the situation. Can anyone help?
Old 01-13-2004, 02:16 PM
Indy8's Avatar
Indy8 Indy8 is offline
Re: Starting my Aurora
How long since new plugs and wires?
Quality isn't expensive, it's priceless.
Old 01-14-2004, 12:47 PM
Re: Re: Starting my Aurora
Not sure, I bought the car w/o asking that question. Is that what you think it is?
Old 01-14-2004, 10:40 PM
Indy8's Avatar
Re: Re: Re: Starting my Aurora
Weak spark from worn plugs and/or degrading wires usually result in slow starting. These engines are very tempermental to less than perfect spark cycle. Otherwise, it could be fuel metering related.
Old 01-15-2004, 12:15 AM
jessb45 jessb45 is offline
I just changed mine just a few months ago. I have the best set of plugs and wires I could find and I get that sometimes. Mine is probably because I need to replace my EGR valve. If the valve is sticking it could cause this.
Old 01-23-2004, 03:12 PM
Thanks.
Old 02-22-2004, 11:29 AM
383LT1Vette 383LT1Vette is offline
Mine just started doing this, after four happy years of instant starts. So how do I change the EGR valve? Have new plugs and wires.
Old 02-22-2004, 10:08 PM
dsatt12 dsatt12 is offline
Just to add a little detail to the fuel metering possibility, Tooltimetech just posted this in the 'hard to start when cold out' thread: http://www.automotiveforums.com/vbul...d.php?t=175110
It sounds like the fuel pressure is dropping off, it is either draining the fuel line back into the tank due to a defective fuel pump or into the engine through a defective fuel pressure regulator. Either one will cause extended crank time, a defective fuel pressure regulator may also cause extended crank when it is warm and a rough idle for the first few seconds the engine starts as it would have to burn the excess fuel that is not supposed to be there.
Old 02-24-2004, 11:06 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
mine has done this for a while now but it really hasn't caused me serious problems so i dotn think it will affect anything, it just wont start as soon as you turn the key.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 03-22-2004, 12:46 PM
auroraborealis auroraborealis is offline
Don't know if you are still having the problem or not. I'm actually just looking in this forum to try to resolve the same problem. I think I've got it figured out. I took mine to the dealer who graciously charged me $350 to replace the fuel pressure regulator. The problem still existed but when I ranted and raved at the manager he showed me the part and said it was definately leaking. I have to admit, I don't get the surge at slow speeds that I used to. They wanted to do some more testing but I was reluctant to leave it for another, "who knows how many dollars". I talked to a couple of mechanic. And one offered two possible reasons. One was the fuel pressure regulator and the other is the fuel pump. He said sounds like the check valve is bad allowing the fuel to drain back to the tank. Test is to turn the key on but not to start. Wait 3 - 5 seconds for the fuel pump to pressure up the line the start. If it starts right up then it is the check valve. So, now I'm trying to find out if you can replace the check valve or do you have to replace the whole fuel pump?
96 Aurora Explosion WKlaassen Aurora 1 03-31-2010 02:24 AM
87 2WD Pick Up - Two Decades of Starting Problems MSW78 Older Pickups 5 11-21-2009 09:45 AM
95 Aurora Fuel Problem? ffinoh Aurora 3 11-18-2009 02:43 PM
2001 aurora passenger locks windows mirror sidneydean Aurora 1 05-01-2009 06:27 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
