![]() Join Date: Feb 2004
performance resistors
I see alot of performance resistors for sale very cheap and advertising up to 20 hp gains. What it looks like is just a resistor that you put in the Air Intake Flow sensor plug that tells the ECU that the engine is under more of a load than it actually is, thus advancing the timing and adjusting the air fuel mixture. They sell these for all types of cars with fuel injection and i would like to hear from anyone that has tried one or knows more about them. Im kind of hesitant to put one on if im not sure what all the effects it will have are. Thanks!!
#2 | ||
![]() Join Date: Jan 2004
Re: performance resistors
there's something on zzperformance.com that talks about that. you should check it out before buying it.
you can do that i have done it and it helps a little i use a 33k resistor i think but just save up and but something usefull
being blown is better than being thrown |
#5 | ||
Re: Re: performance resistors
Here is the information from ZZP's site:
Thanks for the info yall. It is much appreciated. They are goin on ebay for between 5 and 25 bucks. For a .50 cent resistor, thats pretty good mark up.
#7 | |
IT is important what the ECU(PCM) percieves as input but more important is the atmosferic conditions. What is the use to advance the timing when the day or the car or intake air flow is too hot. Instead of getting more timing you will get more KR since the car will knock more because it might be injecting more fuel that would detonate quicker than expected due to the higher temps. The PCM will then KR to protect your car. More KR means less power
