Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-22-2004, 09:17 PM
SATCHI36 SATCHI36 is offline
Send a message via AIM to SATCHI36
Question Turbo Carberator?
Could someone turbo charce a Carberated engine? I dosen't make sence to me if you could.
Thanx
Old 02-22-2004, 10:39 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Turbo Carberator?
Yes you can, and before the invention of electronic fuel injection it was the most common method of fueling a forced induction engine.
Webber, SU, Stromberg holley and Dellorto among others all make carbertors specialy set up for either suck, or blow through forced induction, but most carb designs will work quite well with low boost levels, providing of course the right jet/needle sizes are avliable to supply the increase in fuel required for the engine to run correctly.
Old 02-23-2004, 02:04 AM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
What doesn't make sense about turbocharging a carberated engine? Same concept, just different fuel delivery.
I'd also like to add that in general, draw through systems are not a good idea, if at all possible use a blow through setup. Draw through systems have a larger set of problems.
Beer tastes better upside down.
Old 02-23-2004, 03:52 PM
K wel thanx yall. I was just thinkin' there wouldn't be like enough room for the exhaust to blow the turbines and were the air would go in. K thanx
Old 02-25-2004, 02:49 AM
GTR2b's Avatar
GTR2b GTR2b is offline
Thanx
Look up the Mustang GT from '79-'81 some of the GT's came with the Mazda 2.3 liter 4 cylinder (the same 2.3 that was in the Pinto, base model stangs, Ford Rangers, and too many other cars to count.)
This engine came stock rated at 190hp was was carburated. Do some searching on the web and you'll find it.
Cheers
Want to turbo a 96 Eclipse 2.0 non turbo donidavis Engine, Transmission and Drivetrain 7 12-02-2010 08:23 AM
94 turbo 94camarorider Engine and Transmission 0 05-28-2009 04:54 PM
86 celica turbo 4 sale celica 86 turbo Classifieds 0 04-16-2009 02:42 AM
Ford Probe 1992 2,2 turbo ptq Probe 0 04-13-2009 03:30 PM
89 probe gt turbo TURBO LEAKAGE sweetbiker Probe 0 03-08-2009 04:25 PM
