Go Back   Automotive Forums .com Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 04-03-2001, 09:08 PM   #1
SkylinesKillAll
SkylinesKillAll's Avatar
Send a message via AIM to SkylinesKillAll Send a message via Yahoo to SkylinesKillAll
ok first of all i have a 93.5 g20. when i went to nopi it showed that they have an air intake for 95-99. would that fit in my engie? im sure i could move some stuff around if i had to or did they move the air box after 94? any help would be appreciated
Back in my day we didn't have all this fancy birth control shit; like pulling out.
:flamer: :monkeypis :bathroom::rocket: :badass:
SkylinesKillAll is offline   Reply With Quote
Old 04-03-2001, 10:27 PM   #2
Koojo
Koojo's Avatar
Send a message via AIM to Koojo
You can get a K&N filter. they are for 91-96 g20's. Those are the best filters.
Koojo is offline   Reply With Quote
Old 04-03-2001, 10:42 PM   #3
ni55andriven
I have the Weapon-R intake..also from Nopi. I dont really know how the 93.5 G20 engine looks but it still is an SR20DE so i dont see why it shouldnt fit. Someone mentioned in another post that the air sensor of the 2000 G20 was larger than the 1999 (did i get that right?), which is why an intake from a '99 wont fit a '00. I suppose if the air sensor is the same size of the '99 then itll fit. You could also just get rid of the stock airbox and just put on a cone filter from Stillen of Jim Wolf Technology. The Weapon-R just comes with a colored tube to replace the stock rubber one. Hot Shot (www.hotshot.com) makes a complete cold air intake system for the 91-93 G20 and also the 94-99 G20 for $201. That might be better performancewise. And maybe (?) you can add the AEM water bypass valve on the cold air if you live in a damp/moist area just to be safe. Oh yeah, I changed the Weapon-R filter to a different one. It was made of foam and I wanted something a little different. I dont think it matters anyway. Hope this helps. :smoker2:
1999 G20
ni55andriven is offline   Reply With Quote
Old 04-03-2001, 10:49 PM   #4
SkylinesKillAll
thanx alot. thats exactly what i was lookin for. i appreciate it. :sun:
Old 04-03-2001, 11:40 PM   #5
LCDinmyG20
Question Intake for off road use only ?
Does DEQ allow the use of this aftermarket intake ? Or do you guys just remove the high performance intake and replace it with the stock air box before you go through emissions ? I want to purchase one also but swapping it in and out seems like a pain in the ass.
thanks
I've had my G20 for two days and I love it!
LCDinmyG20 is offline   Reply With Quote
Old 04-03-2001, 11:55 PM   #6
b-b00gie
Banned
b-b00gie's Avatar
Send a message via AIM to b-b00gie
state inspections vary a bit. i live in new jersey, and they do not check anything under your hood. i dont think having an aftermarket airfilter or intake would affect your emissions test. all it does is suck more air in especially at higher rpm's. in new jersey the emissions test is done while the car is idle, so basically the aftermarket unit isnt really doing much at that point. =)
b-b00gie is offline   Reply With Quote
Old 04-10-2001, 04:17 PM   #7
GtRider
Send a message via AIM to GtRider
Intake?????
dude if you lookin for an intake for a 1993 g20 just buy the filter and the adapter!! it'll cost you no more than 50.00...
i own a 1994 g20t and it has a custom cold air intake!!
thats rite its custom!!! all you have to do is go to a muffler place and let them bend you a 3' pipe from under the fender all the way to the adapter and just let them torch the 2 peices together THEN PUT THE FILTER ON THE BOTTOM!!! BAM A CUSTOM MADE COLD AIR INTAKE!!!!
GtRider is offline   Reply With Quote
Old 04-10-2001, 06:25 PM   #8
Koojo
Koojo's Avatar
is that all that the air intake is? a tube and a filter? so the only reason that they dont sell many intakes for our cars is because the tubes arent bent to fit our cars? so can u get a good filter, add it to a custom tube, and connect it to the adapter? on my p11, there are all these wires and metal things coming out of the plastic tube . whats up with that
Old 04-11-2001, 12:12 AM   #9
LCDinmyG20
Re: Intake?????
GtRider,
What brand and model number did you use for the filter and adapter?
How low from the ground did you extend the pipe ?
Thanks for the great idea. :cyclops:
93.5 G20 Black
Newer Gloss Black Paint
16 inch rims
Kenwood 10 disc changer
3inch LCD Mobile Monitor w/ VCR
Looking for a cool spoiler!
Old 04-11-2001, 10:13 AM   #10
G-Forces
Banned
G-Forces's Avatar
Here guys here's some things to consider...
http://www.se-r.net/engine/about_intakes.html
G-Forces is offline   Reply With Quote
Old 04-25-2001, 05:32 PM   #11
dchien
intake: the pipe
hey is the adapter really necessary? does it really give you more horses because you move the filter to a colder area of the engine?
what is every one using as a air filter, k&N? what do people recommend and how much is it?
thanks in advance
d
:flash: :monkeypis :badass:
dchien is offline   Reply With Quote
Old 04-25-2001, 09:58 PM   #12
Koojo
Koojo's Avatar
K&N are really good filters, but they dont make them for '00+ . You might get it custom installed but not from factory. They will cost you around 40 bucks i think....but they last for a LONG time...you just have to clean them out once in a while with a special cleaning product that K&N makes
Old 04-25-2001, 11:27 PM   #13
SkylinesKillAll
hey guys i was jus readin the hotshot website and it said the intake isnt meant for wet weather so if it rains does it mean i should put the old airbox back in?
Old 04-26-2001, 01:17 AM   #14
ni55andriven
No, I don't think so. I don't see why you wouldnt be able to put on the AEM air bypass valve. I saw in the ultra performance catalogue for $44.95...3 sizes too.
1999 G20
Old 04-26-2001, 10:27 AM   #15
G-Forces
Banned
G-Forces's Avatar
I think they say that to cover their asses. If you drive through a huge puddle and hydrolock your motor you can't sue them. Kind of like an 'I told you so.'
240sx s14 CARB Legal Cold Air Intake? Dope Minded Technical 3 01-26-2011 04:48 PM
'00 cavalier, odd noise and oil in air intake/throttle body warik Cavalier Problem Diagnosis 4 04-23-2009 07:11 PM
Important Cold Air Intake Question Accord4u2nv Accord/TSX/Accord Hybrid 5 02-06-2002 02:47 PM
Air Intake Question.... kicker1_solo Engineering/Technical 14 01-09-2002 03:39 PM
