Go Back   Automotive Forums .com Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 01-16-2004, 03:23 PM   #1
mrsyeltzin
mrsyeltzin's Avatar
92 accord suspension
im thinking of getting the eibach pro kit for my 92 accord ex. the springs will lower the car 1.2 inches. What struts should i get so i can have a smooth ride? thanks.
mrsyeltzin is offline   Reply With Quote
Old 01-16-2004, 08:40 PM   #2
BullShifter
BullShifter's Avatar
Re: 92 accord suspension
You mean a smoother ride, there is no such thing a smooth ride on lowering springs because the springs are stiffer. If you can afford adjustable struts, those would be first choice - Koni Yellow, Tokico Illumina, KYB AGX for non-adjustable struts - Koni Red, Tokico HP, Bilstein.
BullShifter is offline   Reply With Quote
Old 01-16-2004, 09:48 PM   #3
whyte Gsr b0i
whyte Gsr b0i's Avatar
Send a message via AIM to whyte Gsr b0i
yeahs if you are gonna go eibach the Koni yellow's are a nice match also the Koni red's
whyte Gsr b0i is offline   Reply With Quote
Old 01-18-2004, 06:41 PM   #4
mrsyeltzin
mrsyeltzin's Avatar
so would the adjustable struts be smoother than the lowering springs?
Old 01-18-2004, 09:01 PM   #5
BullShifter
Adjustable struts allow for tuning of ride stiff or soft using stock or lowering springs. I don't exactly understand your question . . . Springs lower . . .shocks/struts control springs . . . both required.
Old 01-19-2004, 12:21 AM   #6
mrsyeltzin
mrsyeltzin's Avatar
okay now i get it, that the adjustable struts will just control the stiffness or softness of the ride, but the springs are the actual lowering factors. Makes sense, thanks.
Old 01-19-2004, 12:58 AM   #7
BullShifter
Right, now if you went with something like Koni yellow struts, there is an actual adjustable spring perch(change ride height 25mm max)
'95 Accord suspension question? antoniyen Accord/TSX/Accord Hybrid 4 01-08-2010 10:09 AM
accord suspension carolinacamelkille Accord/TSX/Accord Hybrid 0 04-23-2007 08:15 PM
95' Accord suspension questions FadingSunlight Wheels/Tires/Suspension 4 03-11-2006 03:03 PM
Accord Suspension Chez_Bippy Wheels/Tires/Suspension 1 03-29-2005 01:20 AM
1st Gen Oddy/Accord Suspension dblair Odyssey 0 08-11-2004 10:43 AM
