Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 10-11-2003, 04:45 AM
harold_vang harold_vang is offline
CPS/distributor wire color diagram
just put in a JDM 7mgte and somehow the wire to the CPS(cam position sensor) or distributor got cut. i was wonder if anyone has a 7mgte that can tell me how the colors goes to connect to the CPS. there were two black wire, one red and one brown. one balck wire is the bottom right because that was the only one that wasn't cut. now can anyone tell me the other 3 goes? i've check and played and it does spark and everthing but just want to make sure it's right. and what's the correct position of the gear in the CPS so the timing can be correct. i see that there is a mark in the shaft but then on the gear there is a whole and the there is two others on each side of that seems to have a pin in them. how do i position that to make timing TDC?
Old 12-25-2003, 01:55 AM
supracalafragalist supracalafragalist is offline
Re: CPS/distributor wire color diagram
Hi, I have the same problem, just wondering if you ever figured it out, thanks for your time!
-Tom
Old 12-25-2003, 10:07 AM
projectsupramk3's Avatar
projectsupramk3 projectsupramk3 is offline
Send a message via AIM to projectsupramk3
Actually theres only one black wire, theres a red, blue, black, and yellow (the yellow might look alittle brown though after 15 years). Heres how to read the wiring diagram
http://www.cygnusx1.net/supra/library/TSRM/d/D_01.html
And heres the CPS diagram
http://www.cygnusx1.net/supra/library/TSRM/d/D_34.html
One more showing the CPS
http://www.cygnusx1.net/supra/librar.../ig/IG_16.html
Ne = Red
G1 = Green
G- = White
G2 = Yellow
As for the CPS timing check this page
http://cygnusx1.net/supra/library/TSRM/ig/IG_24.html
http://cygnusx1.net/supra/library/TSRM/ig/IG_21.html
Make sure the engine is at TDC (compression). It's pretty much self explanitory.
