stalling out
I have a 96 dodge caravan that stalls out periodically what could it be
Re: stalling out
First off, from Steeler Country, congrats on a well-played Super Bowl.
Some more information would help, like engine size? Is the check engine light on? Have you checked for codes? Have you noticed a pattern when the stall happens, like when it's cold, or sitting at a light, does it re-start immediately or do you have to wait a while before it starts again, etc. |
Re: stalling out
Re: stalling out
Re: stalling out
Ya it just dies when I'm driving it or sometimes sitting at a light
Re: stalling out
Does this happen alot or intermittent?? How many miles? |
Re: stalling out
Re: stalling out
Do you have a code scanner or reader?? I would just check for codes again to see if there are any pending codes. You can also use the key dance to check for codes.on/off, on/off, on and the check engine light should flash( example---flash pause flash flash = code 12, 55 code means end of codes) or you may see a code number in the odometer if a digital cluster. Could also be coil but the intermittent is puzzling. Hopefully Alphabravo or someone else has a better idea. I am thinking if you needed to change the camshaft sensor I would also change the cranshaft sensor. They usually fail about the same time. without throwing any codes.
Had 1994 caravan 3.3 v6 do that same thing , New crank sensor & coil Fix my problem mind had a lot of miles on it.... MPS
