Go Back   Automotive Forums Car Chat > Pontiac > Grand Prix
Old 12-15-2003, 03:44 AM
98GPGT 98GPGT is offline
Question L67 swap
I wanted to swap an L67 into my gt. I was curious if anyone knew what all i would need to swap. I've heard alot of things. I plan on getting the dhp pcm for gtp once i do the swap so thats taken care of. Also How loud it the supercharger sound on gtps. Ihaven't paid attention. Should I be able to make people think its still a gt just with my current emblems. Also whats the best quarter times I can expect with $2k to play with?
Old 12-15-2003, 09:57 AM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: L67 swap
You'd have to get a GTP DHP PCM..because you can't run an L67 with your GT (L36) PCM.
www.l67swap.com
[email protected] <-- He's one of the guys that will come to your house and help you do the swap for a small fee (not sure what the fee is).
1/4 mile times vary depending on the car, and what you do to the motor before you put it in.
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 12-15-2003, 10:28 AM
Re: L67 swap
Yeah I knew about the pcm. But i heard fuel pump is different and so is tranny. I just don't know. Also I'm in illinois I mean wheres that guy located
Old 12-15-2003, 10:30 AM
Re: L67 swap
I wanna do rocker arms and cam for sure. I'm not sure on pulley size probabally switch to F-1 style ram air hood also. I dunno about the rest. I mean its all gonna depend on how cheap i cn get the motor for.
Old 12-15-2003, 10:32 AM
Re: L67 swap
Also I was curious if anyone knew if the new series 3 supercharged will swap in. I know nothing about it except it gets 260 hp. Did they just toss on a smaller puller and call it a new engine?
Old 12-15-2003, 10:50 AM
Re: Re: L67 swap
The guy is located in Appleton, WI. He has a buddy in Milwaukee that helps him with the swaps.
The fuel pump is different, but you don't have to worry about it unless you want to run high amounts of boost. The trans will have to be dealt with though. You can buy a conversion kit for $800, but you can probably get a whole HD trans for around that price.
If you are going to do a cam, I suggest not doing rocker arms as the valve lift will be too high for the stock heads. You will then have to have headwork done. And I hope the hood isn't part of your 2k, because the hood is 1k by itself. As for pulley size, again it depends on what you do to your car.
I wouldn't go for the SIII S/C. www.zzperformance.com is supposed to have some new modded M90 coming out soon that is supposed to be way better than any stock S/C out there.
And as for the SIII motor, it is a combination of many things, including a slightly smaller pulley if I remember correctly.
Old 12-16-2003, 01:15 AM
I think I can handle the swap. A friend of mine put a l67 in a grand am gt for a guy so i think between us we can pull it. Yeah I know how much the hood costs and I consider that outside of the 2k. I mean 2 k for the motor sutff. I'm gonna just try to find a wrcked gtp and pull the tranny, motor, and fuel pump, maybe even the pcm so I have something until i get the dhp pcm. I've been to zz performance before and looked into the cfsc before but decided that my motor has enough miles on it already, but i didn't know they were modding a knew eaton. I'm looking to get into the mid 12's by the time I'm done. I'm looking for alot of torque and low end acceleration then worry about top end later. What do you think I should do? I mean you seem to know more than me about this whole project. I already have the basicis: cold air, high flow cat, and borla exhaust. (thought about swapping in loud mouth found good deal on it). What do you think it will take to acheive the numbers i want and still have a daily driver?
Old 12-16-2003, 06:39 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: L67 swap
Usually the SC does not make extreme sounds. In my case after they moded it I Can tell you that after 2750 rpms the only thing you hear(car has OEM exhaust) is a mild whistle. So if you race with windows up and the other guy to no one would tell you have a l67 on your car.
Rom, have you started your migration project already?
Old 12-16-2003, 10:10 AM
Re: L67 swap
12s are hard to hit. It takes a lot of tuning, or an Intercooler to hit 12s. If you want torque, then you should stay with the GT 3.29 gears, or go one better and install 3.69 gears. You'll also NEED an LSD or ATB differential if you're going to stay with the GT tranny. If you want torque, then you will def. want a cam and headers. With that cam, you'll need to install CompCams high-load valve springs. Which ones you install depends on how radical you want to get with the cam. You'll want to have some machining done on your heads, SC, and lower intake. You'll want to upgrade your TB to the LS1 package that ZZP sells so your engine can breathe better. You'll want to get an aftermarket CAI or FWI. The last thing you'll want to have done is have your motor and PCM dyno-tuned by the guys at DHP ( http://www.digitalhorsepowerinc.com ).
That's kind of a generic run-down. I have a list made of what the killer NON-IC'd engine configuration would be. But it's on my PC at home....and I'm at school in class right now.
And Kilroypr..I have not started my project yet. I'm still paying off some X-mas stuff, and working on my 90 Turbo at the moment. I will be starting the L67 project towards the eend of next month...depending on wether or not I can keep myself from buying the 55" Toshiba HDTV I'm looking at.
Old 12-16-2003, 01:41 PM
GTPCatz GTPCatz is offline
Banned
Re: L67 swap
Easier if you stick with your engine and just get a CSC kit....you'll be faster then alot of GTPs with this setup
http://www.zzperformance.com/zzp/pro...gal_sc_kit.htm
Old 12-16-2003, 01:48 PM
kilroypr's Avatar
Re: L67 swap
55" that is expensive
Old 12-16-2003, 02:07 PM
kilroypr's Avatar
Re: L67 swap
55" HDTV is expensive. That will be great for the Rose Boul and stuff like that ... Enjoy
Old 12-16-2003, 02:11 PM
kilroypr's Avatar
Re: L67 swap
Rom, Somebody told me that there is a way to compute the transaxle effective gear ratio based on the tire hight and installed gear ratio. Do you know anything about this? Or where I can find that. I checked on auto.howstuffworks.com with no luck
Old 12-16-2003, 11:34 PM
I would like to get a csc but its $4k. I don't want to pay that much when I can probabally buy an L67 swap and mod it to be faster for the same 4k.
Old 12-17-2003, 11:28 AM
kilroypr's Avatar
Re: L67 swap
GPGT, what is important for the 4k swap is on what condition it is on. There is a website, http://www.worldparts.com where you can request based on your VIN number quotes for the parts that you need. These parts have OEM waranty and have good prices. A reman transaxle could be around 1200, reman sc around 1000 and reman engine around 1800. All these parts have OEM waranty and depending on who do the mods they will not loose them. Just a tought.
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
L36 to L67 swap maxbfresh Grand Prix 12 03-05-2009 10:24 AM
L67 Swap Baby pontiacs98 Grand Prix 3 03-07-2008 10:51 AM
l67 swap 1969Stang Century 0 02-22-2004 12:05 AM
l67 swap bgchrs2004 Cutlass Series 1 10-16-2003 07:15 PM
