Go Back   Automotive Forums .com Car Chat > BMW > 7 Series
Old 03-04-2002, 09:14 PM   #1
Gerry
12 Sweet Cylinders
Hi; New to the board and I just bought an E32 1990 12-Banger Beast. Love at first sight! BIG QUESTION What am I in for here in terms of major problems. Everything is working right and it drives smooth and strong. I just know its too good to true. No oil leaks yet. PO had center drive shaft bearing replaced along with valve cover gaskets. Oil pan gaskets appear clean and oil free. The right rear shock is leaking just a little bit. No load leveling option ( no switch on dash ) The heat shields on the front exhaust pipes and rear muf are rotten but do not leak. 82k miles and clean as whistle......... Any tips would be very appreciated...Thanks again guys
Gerry is offline   Reply With Quote
Old 07-07-2002, 02:24 PM   #2
wlerner
I think your caqr sounds wonderful. As far as load leveling with no switch, I am fairly sure there is no switch to turn this option on and off. You should feel the car shift slightly when starting. You can also disable this option and have a normal suspension. Load leveling is very expensive to fix. I know that BMP sells a kit to disable this function.
Congrats on a wonderful automobile!
wlerner is offline   Reply With Quote
02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6 osuyaqui Dakota 3 04-09-2009 09:49 AM
P0305 Cylinder 5 Misfire wmuwop Explorer | Explorer Sport Trac 3 03-31-2009 07:40 AM
Weird #3 cylinder misfire gesellman Trooper | SLX | Bighorn | Wizard 2 03-07-2009 12:31 AM
Ignition Lock Cylinder & Worn Keys... Intuit Escort 2 02-18-2009 10:51 AM
