Old 12-12-2003, 04:09 PM   #1
Magik Si
Magik Si's Avatar
IAT...wire has pulled out...Help!?
My Intake air temperature sensor is being flashed by my ECU...so I go on the hunt to find the thing...found it! (very excited, might actually fix something)...oh-oh. One of the wires has 'torn' out of the little white sensor casing...I can see the little stubby bit still stuck in the sensor...one of the two wires (green one) from the harness is still ok...but there is not enough wire to perform a "fix" to the red wire...the guy at the parts counter at Honda said I'm screwed and said I'm going to have to buy another 'complete' engine wire harness!!! That's like $700!!!
How screwed am I???
Jason
www.jasonlorette.50megs.com
90 Civic HB Si - D15B1 + MPFI
Magik Si is offline   Reply With Quote
Old 12-12-2003, 09:53 PM   #2
Magik Si
Magik Si's Avatar
I snapped a couple of pics:
Jason
Old 12-12-2003, 11:54 PM   #3
johnb16a2
johnb16a2's Avatar
You've got a couple of choices. You can take the plug apart (not too hard) and try to repair it that way (not my choice) or you can go to the junkyard get the plug you need (with plenty of extra wire attached) cut off the broken plug and solder and shrink wrap the connections. I had to do this for my dizzy power supply plug and it works great (knock on wood).
johnb16a2 is offline   Reply With Quote
Old 12-12-2003, 11:57 PM   #4
cot
cot's Avatar
Re: IAT...wire has pulled out...Help!?
yeah, it's just a matter of finding that connector used and replacing it
the honda guy was trying to take you if he really suggested buying a whole new harness
cot is offline   Reply With Quote
Old 12-13-2003, 01:19 AM   #5
BullShifter
BullShifter's Avatar
I have a harness laying around at the shop, I'll check if its got the same connector. If its the right one, you can have it for the shipping cost, couple bucks.
BullShifter is offline   Reply With Quote
Old 12-13-2003, 02:45 AM   #6
Magik Si
Magik Si's Avatar
Re: Re: IAT...wire has pulled out...Help!?
Sounds good to me!! Let me know!
Jason
Old 12-16-2003, 02:17 AM   #7
BullShifter
Re: Re: Re: IAT...wire has pulled out...Help!?
Check PM's
Old 12-16-2003, 10:03 AM   #8
Magik Si
Magik Si's Avatar
Right back atcha!
Jason
2009 Matrix S 2.4L IAT Sensor Johnnies2000 Corolla/Matrix/Voltz 2 11-24-2009 03:30 PM
Pulling out Relay switches Help? kyle172 Leganza 0 08-28-2007 12:57 AM
Help! 97 won't start, pulling out hair ta2tony C/K 22 07-28-2007 07:46 AM
Help! 97 won't start, pulling out hair ta2tony Silverado 4 07-17-2007 03:55 PM
This has to be a faulty Wire!!! Has anyone got a suggestion which wire it could be? Decebal Lumina 11 07-31-2004 12:59 AM
