Go Back   Automotive Forums .com Car Chat > Engineering/Technical > Tires and Wheels
Old 10-30-2003, 05:54 PM   #1
Miataracer
Miataracer's Avatar
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
rear disc conversion
I HATE DRUMS!!!
To convert rear drums on a '94 Civic EX to disc what all would be needed? What I want to do is take the rear assemblies needed off of other junk yard Civics... I will probably just grab the entire assembly from whatever car I find but right now I am trying to price things out a little bit.
-rear trailing arms
-left & right calipers
-left & right rotors
-brake lines
What else? There has to be more to it than that...?
LS1 RX-7 Zoom Zoom
Miataracer is offline   Reply With Quote
Old 10-30-2003, 08:11 PM   #2
SilverY2KCivic
Cali Guy
SilverY2KCivic's Avatar
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: rear disc conversion
Originally Posted by Miataracer
I HATE DRUMS!!!
-rear trailing arms
-brake lines
Rotors, calipers, brake lines, rear lower control arms and rear trailing arms.
This link
and this link
should give you an idea of the parts you'll need to do it. And if I'm not mistaken, you can use either CRX Si parts, or 3rd or 2nd gen Integra parts.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
SilverY2KCivic is offline   Reply With Quote
Old 10-30-2003, 09:31 PM   #3
Miataracer
Miataracer's Avatar
looks like for around $700 I can get the stock rear disc set up from the junk yard including 4 new rotors, all new pads, and braided stainless brake lines
stock rear disc set up will fit under the 14 inch stock steelies correct? I ask this because during winter the stock steelies are what I use.
LS1 RX-7 Zoom Zoom
Old 10-31-2003, 01:40 AM   #4
hondaracer
Yes the stock rear disc setup will fit under the 14's. 700 is getting kinda steep for a stock set up. A rear disc conversion with calipers, caliper relocation brackets, new pads, bigger rotors, and stainless braided lines is only going to cost me about 810 and thats only 110 more what you're planning on doing. I would just save a little more and get an upgrade, but the only downside is that you'll have to run your aftermarket rims year around and you probably don't want to do that.
hondaracer is offline   Reply With Quote
Old 10-31-2003, 01:47 AM   #5
Miataracer
Miataracer's Avatar
yeah I dont wanna run high performance tires in snow... it just doesnt work!! (got stuck with them on in a snow storm last year, YIKES!) thats why the trusty 14x5 stock wheels with all season tires are still around
Also, my cost included:
full set of 4 brembo stock replacement rotors, 2 front, 2 rear
new pads front and rear
new stainless brake lines front and rear
so I could cut the cost down a good bit by running stock brake lines, and not replacing the front rotors and pads, but I figured if I was doing the brakes I would dig in and get them all the way I want them... you know?
LS1 RX-7 Zoom Zoom
Old 10-31-2003, 02:19 AM   #6
hondaracer
Yeah thats cool. Do what you gotta do to get through that snow. I'm glad I don't live in it like you do. It never snows here thank god.
Old 10-31-2003, 02:55 AM   #7
Miataracer
Miataracer's Avatar
lucky!!!
0123456789
LS1 RX-7 Zoom Zoom
Old 12-09-2003, 02:44 AM   #8
E Honda
E Honda's Avatar
Send a message via Yahoo to E Honda
Question Re: rear disc conversion
What is the correct master cylinder and proportioning valve for the 4 wheel non abs set up....What models were equipped with 4 wheel non abs...? Also are the motors in the 95 integras worth swapping into a 93 civic sohc?[color=darkorange][font=comic sans ms]
E Honda is offline   Reply With Quote
