99 rodeo hard starting
My 99 rodeo has trouble starting. It takes longer than it should cranking(sometimes 15 seconds or so) It has 59 k miles on it, so I changed the plugs, they were pretty messed up. It seemed to start better, but only for a day or two. Now it is back to the same. Any suggestions or help??
thanks Luke |
Isuzu Guy
![]() Join Date: Jan 2004
Re: 99 rodeo hard starting
http://www.geocities.com/endre_rl/isuzufaq.htm#faq22
My Truck takes a long time to start (cranks an excessive length of time). Leaking fuel pressure regulator is the common cause: photo of the fuel pressure reg http://forums.vmag.com/suvrodeo0300/messages/785.html Quote from the above link: The original symptom was a Check Engine Light with a #6 cylinder misfire code of P0306 when set at idle, or a random misfire P0300 when set while driving. The #6 was obviously running rich as indicated by the the spark plug. Eventually it became a hard start also. Here's the fix: The fuel pressure regulator was leaking fuel down it's manifold pressure vacuum line. The vacuum line attaches to the manifold right above the #6 port, that's why the richness only in that cylinder. Fuel pressure regulator part # for 1999 Rodeo: 8-17113-398-0 Cost $54 from St. Charles Auto, http://isuzu.stcharlesauto.com/ (my local dealer's cost is $75. St. Charles Isuzu got it to me overnight for $65 which is cheaper than the local dealer sells it for. Funny that I could get it quicker and cheaper from Wisconsin than from the dealer down the street here in California). I was in contact with a guy named Merlin. Great service. See below for tips on changing this part in a 1999 V6 Rodeo M/T. Read the whole thing prior to starting the job. I replaced the regulator in about 40 minutes and I wasn't rushing. It seems to have completely fixed these problems: 1) Erratic Idle (needle now rock solid at 750 RPM) 2) Frequent stalling at idle - doesn't stall at all 3) Hard starting - starts like it used to. No need to give it gas . 4) Intermittent CEL light - gone The regulator has no electrical connections. It is a diaphragm operated relief valve mounted on the fuel rail. Before attempting to change the part, you need to ensure that you remove all fuel pressure from the system. The following procedure from the service manual works like a charm. I used this procedure and there was absolutely no fuel pressure in the system. No fuel leakage at all when I removed the regulator. Fuel Pressure Relief Procedure (works great). 1) Remove the fuel cap. 2)Remove the fuel pump relay from the underhood relay box. 3) Start the engine and allow it to stall. 4) Crank the engine for 30 seconds. 5) Disconnect the negative battery cable. Caution - to reduce the risk of fire and injury, it is necessary to release fuel system pressure before servicing fuel system components. Even after relieving fuel system pressure, a small amount of fuel will likely be released when servicing fuel line connections. Cover fuel line fittings with a shop towel before disconnecting the fittings in order to absorb any fuel that may leak out. Leave the fuel pump relay out and the battery disconnected while you change the part. Changing the part on a 1999 Rodeo is a bit different than the service manual shows. The regulator does not screw into the fuel rail. It sits down into the rail and is held in place by a snap ring. Once you have removed the fuel line and the bracket that blocks access to the regulator you will clearly see the regulator and the snap ring. Before you start the job make sure that you have a pair of snap ring pliers that fit. Use the new snap ring that comes with the part to ensure your tool will do the job. You will also need to modify a 6mm allen wrench by cutting the short end to within approximately 1/4" of the 90 degree bend. You will need it to remove the rear most of the 2 bolts that mount the bracket that is over the regulator. Ideally you should have two 6mm allen wrenches, an unmodified one for the front bolt and the modified one for the back bolt. For ease of removal of the snap ring that holds the regulator in place on the fuel rail, it can be easily rotated once you have access to it by hand using the fuel line nipple for leverage. This enables you to turn it to a position where the snap ring is easily maneuvered out. Make sure that you remove all parts of the old regulator from the fuel rail before attempting to install the new one. Make sure that you remove the large blue o-ring, the wire mesh screen and the small black o-ring from inside the fuel rail. Just make sure that you remove all of the parts that you see on the new regulator. Once you have it all back together, install the fuel pump relay and hook up the negative battery cable. Also make sure that you put the fuel cap back on. Start it up. Done. http://www.automotiveforums.com/vbul...=159663&page=2
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
Hey, thanks for the help about this part. I am planning to change it this weekend if the part actually gets here! I'll keep a post for the info.
thanks |
Let us know how the repair turns out.
Thanks, Dale |
![]() Join Date: Nov 2003
Hey I just want to thank you guys, I had exactly the same problem, i have been chasing it arround for about 6 months. I put on a new fuel press reg today (took about 1 hour) and it runs like new. THANKS Tom
