Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-10-2003, 07:54 PM
redeyes redeyes is offline
95 rear struts
I need to replace the rear struts on the wifes car, and my Haynes manual says I need a special tool to compress the rear leaf spring.
Anyone know what the special tool is and what it looks like.
Also I can't see why you would need to compress it, Looking at it I would think you just need to support the knuckle with say a jack.
Thanks
Old 12-11-2003, 02:17 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: 95 rear struts
you need the tool definately, and I don't think you can obtain one, due to the risk of injury when compressing that spring, you're better off just having it done at a shop, it's not cheap either, luckily I had a well equipped mechanic friend that did mine for $100.
Old 12-11-2003, 08:18 AM
shekky shekky is offline
Banned
Send a message via MSN to shekky
Re: 95 rear struts
if you live in canada, you can borrow the tool from canadian tire for free.
Old 12-11-2003, 08:46 AM
The Burning Rom The Burning Rom is offline
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: Re: 95 rear struts
You don't need the special tool to compress the leaf spring. C-Clamps will work just fine. Although, as I recall, you don't need to compress the spring to change the rear struts. Search the forums at this site: www.w-body.com for instructions/tips on changing rear struts.
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
Old 12-11-2003, 09:57 AM
bustedratchet bustedratchet is offline
Re: Re: Re: 95 rear struts
Jack it up under the control arm to keep the suspension compressed. A Problem you may run into is that on the rear arms (some don't have them some do ) you might see a plastic piece on there that has an upper metel plate that is held on with the lower strut bolts. If that comes apart it is a real pain the reinstall it. In the center of that upper plate there is a hole. Monroe struts give you the bolts to put in there the lower plate is threaded to keep that plastic spring from coming apart.
