Old 07-22-2005, 05:56 PM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
HOW do you get the Ball joints out from the upper A-Arm?
I need to know how to remove the ball joint completly from the A-arm? I just got a new Ball Joint Camber kit from SPC and it says to press out the balljoint. All i have is a big machine press but i dont know were to press on the balljoint to get it to pop out. And do i need to rent a balljoint press from autozone or something?
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 07-22-2005, 09:40 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: HOW do you get the Ball joints out from the upper A-Arm?
Your best bet, IMO is to bring it to a garage, they'll have all the right adapters and most won't charge more that $20 USD. GL
Old 07-23-2005, 03:42 PM
anthony90si anthony90si is offline
i believe there is a c clip that has to be removed then it shouldn't be a big deal to press it out if you got a press. i did it with the lower ball joints and they came out ok.( i used a hammer though)
stock b18a1 14.97 @ 92 mph
Old 07-24-2005, 01:57 AM
Sparsky Sparsky is offline
umm... i thought on the civics/crx's the upper ball joint is part of the upper control arm and sold as a unit.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Least this is the way i've seen them, except for the 1/2 degree ones that cost alot.
http://www.cardomain.com/memberpage/765867
Old 07-24-2005, 05:41 PM
Well in my hanes book it says the the upper A-arm balljoint is NOT removable. So why the hell did they say it will work for 89-91 civic/crx???? Is there a way to cut it out or something? Can i take a front A-Arm from a 92-95 civic and put it on my 4th gen or are they diffrent. Because the 92's have a removable ball joint.
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 07-24-2005, 06:18 PM
Ok... I looked at a new set of upper control arms w/ ball joints I bought recently. On the underside of the controll arm there is a "C" clip. Looks like I'd have to take the ball joint boot off then the C clip and it might come out.
But like I said this is a new set, not OEM. So I can't say if the OEM is set up the same way.
Old 07-25-2005, 03:08 PM
dagoEF's Avatar
dagoEF dagoEF is offline
the OEM ones are not removable, a lot of the replacement ones are though
