Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 11-20-2003, 07:17 PM   #1
jon_mariani
Send a message via Yahoo to jon_mariani
clip on window winder
where is the window winder clip? is it visible or in the door panel like that area? because if it is in side the dorr panel area its super hard 2 get 2 thanks.
jon_mariani is offline   Reply With Quote
Old 11-20-2003, 11:31 PM   #2
wutangteo
Re: clip on window winder
i don't know if this clip is what you are talking about but when i took my side door interiors out to install new speakers, there was gold clip that held the interior. that is probably what you are talking about, if it is and you need more info, just ask ight
wutangteo is offline   Reply With Quote
Old 11-20-2003, 11:38 PM   #3
wutangteo
my fault, please ignore what i said before, you were talking about the clip that holds the window crank. anyways use a small screwdriver (or sometihng that fits in the hole of the crank, that'll get it out
also, search on google "remove window crank cavalier"
Old 11-24-2003, 07:43 PM   #4
maximus1620
using a screw driver is a good way to get it out but is still a pain in the butt. there is a tool made for those clips but it doesnt work. it takes swearing and a scratched door. it takes a little bit, once you install a few speakers you will get a hang of getting those stupid things off.
maximus1620 is offline   Reply With Quote
Old 11-29-2003, 09:19 PM   #5
sweetwhiteCAV
Send a message via AIM to sweetwhiteCAV Send a message via Yahoo to sweetwhiteCAV
sweetwhiteCAV is offline   Reply With Quote
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 02:44 PM
window regulator daspyderman LS | MKZ 6 03-09-2009 04:07 PM
Window regulator troubleshoot anfrhm Sidekick 0 02-19-2009 01:40 AM
xj6 window winders charl du plessis XJ6| XJ8| XJ12 | XJR 0 05-21-2006 02:56 AM
how to get window winder off jon_mariani Cavalier 2 11-20-2003 07:04 AM
