Is it true that you want as much torche as you do hp (or maybe the torche exceeds the hp) or does that not matter?
Re: torche and hp
Their is debate about this among car buffs, but basically a heavier car will do better with more torque and a lighter one will want more hp. The gearing is a major factor as to which is faster. A car with a lot of torque can get by with mild gear and will have a broader power band. A car with a lot of HP will generally have a smaller power band and need low gears and a manual transmission to keep the car in its power band.
In a nutshell torque requires a large displacement motor (heavy) and hp compromises driveablilty (no low speed power). For example a motorcycle has a lot of hp and a 18 wheeler has a lot of torque. If you swapped motors the diesel motor would crush the motorcycle, and the motorcycle motor wouldn't budge the 18 wheeler. So you have to look at what kind of vehicle you drive and what kind of driving you will be doing before you decide if you need more torque of hp. |
Re: Re: torche and hp
Good explaination on the difference between torque and horsepower. I would add that more torque tends to help initial acceleration while horsepower helps top speed. Which is more important is up to you.
1971 Buick GS Convertible 350-4bbl w/ 3-speed Auto 1 of 599 made Modifications: None - Totally stock! Former owner of: 1969 Buick GS 400 Convertible Modifications: 430 4bbl. V8 (from a '68 Riviera), Stage 1 spec Carb, headers, 2 1/2" exhaust, transmission shift kit, and column tachometer - to name a few ... |
