Old 11-20-2003, 11:56 AM
ChrisD ChrisD is offline
Question Please someone Help 96 Blazer Wont start unless I jiggle the wires
My 96 Blazer wont start unless I jiggle the wires before hand that are connected to the battery.
It is a small rectangle shaped plug that one end goes to the battery and the other end goes into the wiring on the side wall passenger side of the truck. When I have came to a stop before it has just cut off and when I turn the key all lights come on but as soon as I turn it over everything turns off and I get no power until I jiggle the wires? Also when I turn on my blinker when it is running the amp gauge goes up and down between 12 and 14 and the lights dim in the vehicle. CAN SOMEONE PLEASE HELP...SINGLE FATHER ONLY WAY TO WORK AND HIM TO SCHOOL.
Old 11-20-2003, 05:45 PM
airforceone's Avatar
airforceone airforceone is offline
Send a message via AIM to airforceone
Does it have a good battery? Take it to an Autozone and have them test it. (Free!) Since you have to jiggle the wires, maybe you will need to get some new battery terminals. From what you descibed, I think this should fix your problem. When you go to Autozone, (a valuable source for information) describe you problem to them and they should be able to help you on the spot. Even if you have to replace the terminals, that job only takes a few minutes.
The world's greatest Air Force...well, at least we blow up the most stuff.
Old 11-20-2003, 06:49 PM
Battery is good so is the alternator.
I dont really understand it.
Old 11-20-2003, 06:52 PM
The terminal is the metal clamp or screw that connects the battery to the wires.
Old 11-20-2003, 06:53 PM
Re: 96 Blazer wont start unless I jiggle the wires
Yes and those are good?
Old 11-20-2003, 06:56 PM
Then check where the wire connects to the terminal.
Old 11-20-2003, 08:10 PM
ahhhhhhhhh negative battery terminal was loose. Hopefully this fixed the problem. Will not know until in the morning or after a few starts
Old 11-20-2003, 08:29 PM
to a job well done
Old 11-20-2003, 09:16 PM
Thanks Man!! I appreciate it alot!! Love the gif of the welder..
I have a littel site but its for where I am from but hey check it out sometime..www.thehsvspot.com
Old 11-20-2003, 09:22 PM
I just checked your site.....I don't think it applies to me as I'm on the other side of the world....
95 Chevy S-10 Blazer won't start unless i use starting fluid ktscott1 Blazer 4 10-04-2010 08:18 PM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
91 C1500 wont start unless gas petal is on the floor stuntmanjake C/K 6 01-29-2009 04:46 AM
2000 explorer xlt wont start unless i hold the gas wide open tacoma man. Explorer | Explorer Sport Trac 2 06-01-2004 10:52 PM
