![]() Join Date: May 2006
carb to fi
i have a 86 hatch with a 1.3 carb in it and i was wondering if there is a way to convert that engine to a fuel injected.
AF -Advisor
![]() Join Date: Feb 2004
Re: carb to fi
Yes, but you might be better off buying an SI model.
Converting to FI means you will need a donor wiring harness, fuel pump, ECU and a complete intake manifold. The 1.3 head was not designed for FI so if you want to use it you will need to modify the intake runners to allow clearance for the fuel injectors. You will also need to block off the carbed fuel pump and rod. You could also swap a complete SI head, or better yet swap in a complete D16A1 set-up from an '86-'89 Integra. Personally, I'd keep it carbed and run either dual Weber/Mikuni's or motor cycle carbs. |
Re: carb to fi
well reason i was asking is cuz i can get ahold of complete intake manifold and comp and harness... what is a cheap carb for it
AF -Advisor
Re: carb to fi
Intake manifold, ECU and harness for which D-series motor? Not all D-series motors are the same.
Are you looking for a cheap replacement carb or a performance carb? |
Re: carb to fi
a cheap replacement carb... just something to get it running better to get it sold
