what do lower tie bars do???????
I always wondered what a lower tie bar does to the suspension of a car.
Is it the same as a rear sway bar? I always see them on integras and sometimes civics. I will have to admit, they look really nice. However, I'm just curious to know how much that bar actually helps and what's its purpose. Thanks
Purehonda Moderator since March 2000 Purehonda Member since Feb 2000......and still counting ![]() http://www.sounddomain.com/id/natcc99 |
Re: what do lower tie bars do???????
Man what are you stupid? What does an upper tie bar do? hehehe...
(hey you know im kidding before someone posts up "gee what an asshole that sparq is... hahaha) But actually I guess you might wanna wait till someone with a more "technical" answer to post ~ remember im just an audio dude
AF's Official Asshole RIP AUNIE |
Re: Re: what do lower tie bars do???????
![]() J/K To be honest no one really knows what they do, as far as being noticable. What I can tell you is what the point of installing them is, to strengthen the sub frame, basically, if you wanted to auto X this is a legal way to beef up your frame. Beacsue you can't have the frame reinforced by adding steel bars etc. The bars, will strenthen the pickup points if you have sway bars installed, in fact they are a must especially in the rear, bracuse of all the stress they put in the sub frame. It is said they help in higher speed situations where frame flex under heavy cornering is more extreme. here are mine rear (not on right now) ![]() front
M.Sanew - AutomotiveArticles.com |
they do the least of any bar on your car...the front strut, rear strut, front tie, lower tie all do little to nothing for you in a corner...they make your car feel more responsive, which is a good thing, but they won't do what a good sway bar setup will do for you
heeeeeeeeey....why is everyone calling me stupid all of a sudden?!?!?!?!
![]() thanks sparq.....look what you started!!!! Yeah, I know you don't know much about suspension...you're an audio guy. I think of you as the audio god!!!!!!!! I remember when you pretty much took over the audio forum on purehonda!!!! ![]() If you like....visit my page about my updated soundsystem. http://www.sounddomain.com/member_pa...=121440&page=7 Please tell me what you think.....because I know you will have a good insight on the topic. Plus, your opinion means a lot to me, oh might audio god!!! ![]() [email protected] . . . . . .going back to the topic........... I know that it strengthen the frame and prevents body flex. I was just wondering what it does for handling performance. I guess it sounds likes it just makes your car more responsive. What about rear sway bars?!?! How much difference is that from a tie bar??? |
hello
thanks for some answers. it looks like it would be better to by a anit-roll bar for the rear as oppose to a tie bar. I have an LX accord and it's sad because it does not have a rear sway bar Only the EX model come with them. (assuming I'm correct on that above info) which brand would be the best for such a bar? I know Eibach makes them.
just to ad a few thoughts...
First off, tie bars add to the responsiveness of the steering due to their increasing structural rigidy at key suspension to frame points. They do make a sizable difference in chassis rigidty and suspension performance, which is why you'll find them as factory equipment on cars like the integra Type R. Which ones are most effective just depends on the application.
Secondly, sway bars increase weight transfer, not decrease it. Adding a thicker rear sway bar increases both lateral weight transfer from the inside to outside wheel, and weight transfer from the front to rear of the car. That's precisely why they decrease understeer levels inherent in the base chassis. One other thing to remember is that stiffer sway bars do not necessarily increase the handling ability of a car. They only do this if the car isn't neutrally balanced to begin with or has camber problems during hard cornering, other than that their main benefit is in driver confidence and not increased adhesion.
'03 Corvette Z06 '99 Prelude SH |
Re: just to ad a few thoughts...
Re: Re: just to ad a few thoughts...
![]() get some 15" wheels my friend ![]() perhaps some bronze Si wheels
Tires of course are the #1 thing. They're the only thing that actually creates traction, the rest is in the suspension and frame it works off of (think of it as the suspension's backbone) and how well they keep the tires solidly and flatly aligned on the road surface. The suspension also has a great deal to do with feel and controllability, which is what we are after during suspension modification. Alignment, spring rate and damper rates are what we modify, and their effect is anywhere from barely felt to so important that the cars needs to be driven with a different style to be properly controlled. Again, in the confines of one size fits all, the only modification I can always recommend is great tires. If you start getting Honda specific or car specific though, I can always recommend better than stock shocks and almost always to get moderately stiffer springs.
Sorry to sound so vague, but I personally don't feel there are many blanket statements when it comes to suspension modification as to what works best. You have to present a specific questiofor a specific car in order to really get a good answer, but again that's just my opinion. Hope this helps explain things, peace.
It is nice to sit back and have someone answe shit for you, Texan you are such a whore!
I can't answer this from a technical stand point., but I'll tell you what I've experienced with mine since I had it installed on my '00 Civic coupe. I always noticed that under moderate speeds on a tight turn, or one of those 270 dgree turn freeway on/offramps, the tendancies of my car, was for the rear end to want to slide out towards the opposite direction of the turn, that I'm sure is mainly due to my POS stock tires/rims setup, but it happened none-the-less. Once I got my lower rear tiebar installed, my car (and steering) felt more responsive, and more balanced (from the rear mostly) under hard cornering. The rear didn't have as much of a tendancy to slide out anymore, and I could push the car faster in a turn or curve before the rear would feel floaty in means of traction (gotta love FWD
). I hear as for bars on your car in terms of brace bars, the front upper, and the rear lower are best to get. And as mentioned above, they certainly look sweet n a car, I like the look of the DC Sports lower tie, the best. A nice bar I'de love to own is that SWEET Comptech swaybar/tiebar all-in-one unit they make/sell for around $370. It's a tiebar mounted onto a sway bar, so you get the weight transfer and hadling abilities of a swaybar, while ALSO getting the added chassis rigidy and stiffening of a tie bar. Very cool indeed. :sun: Here's a pic of my tie bar on my Civic:
Silver '00 Civic EJ6 Coupe PureHonda original member since Feb. 2000 D-series revolution For pics of my baby, click here! All rights reserved... All BITERS served! "The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket." i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift hessemer69 on AIM |
Hello SilverY2KCivic
Thanks for you insight and experiences. In response to your views....I'm surprised about my car. The reason for this is because my rear does NOT "float" under hard turns. The rear stays with me and it's my front end that I'm worried about. I seem to be getting a lot of understeer....a condition where my front wheels lose traction first. Sometimes, I want to pull my e-brake to swing my rear around, but I don't do that since I'm too afraid to pull such a move. I think I've been playing GrandTurismo too many times HEHEHEHEHEHE I've noticed only under EXTREME conditions that my rear will loosen up and start floating. (that was the time when my rear swung outwards and cause my car to go sideways down the road. Scary...and I have never done that again )Anyways...for a car that seems to have a lot of understeer, what can one do to balance that act?!?!?!?!?!?! Tighten the front end or tighten the back end? |
