Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-24-2003, 02:11 AM
ZackKVtec ZackKVtec is offline
Registered User
gsr mod help
whats up i have a 96 integra gsr, i have an aem cai and a greddy sp catback, im thinking of adding : pulleys, cam gears, cams, high flow cat, headers, a lightened flywheel, and a new clutch. does anyone have any suggestions for what i should add next out of that list and any other stuff you have added to your car that you think are worth while , thanks alot guys
1st mod: aem cai noticable sound difference, little speed difference
2nd mod: greddy sp catback, medium sound difference, huuge power gains, when i used to shift into third vtec would take a second to come on, now when i shift into third i chirp the tires and vtec is already engaged ::::swwweeeeeeeet::::
Old 10-24-2003, 02:39 AM
Spectre927's Avatar
Spectre927 Spectre927 is offline
Send a message via AIM to Spectre927
I dont think the exhaust has anything to do with VTEC engaging earlier. Maybe you're just getting better at driving, or you're tires are balding. Also, you might consider an OBD1 conversion. I wouldn't go with the harness to ECU, though you could, but maybe a prebuilt OBD1 that goes plugs right in, my local shop is building them(hondata is thinking about buying some off of them) $360 a peice.
Old 10-24-2003, 07:18 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
Re: gsr mod help
uhm...hate to break it to u, but the exhaust isn't going to change ur gear ratio (which would effect wut RPM u shift into).
maybe ur shifting at a higher RPM...as for the tires...agreements w/ spec.
ur not going to see the torque gains that u'd need to make a difference...
as for the next mod, i'd purchase HONDATA then goto a dyno an tune it.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 10-24-2003, 10:14 AM
Registered User
come to think about it , maybe i am getting better at driving, but i think that the when i freed up the extra air with the exhaust+intake i made the conversion into vtec a little less harsh that it was before, also my engine seemed like it was choking alittle bit before i hit vtec before so when i freed up that excess air i was able to hit vtec earlier (or so it seemed, my engine was just winding up faster) thanks guys, but honestly what is hondata and odb1, could you explain a little.
Old 10-24-2003, 12:53 PM
Spectre927's Avatar
OBD1 is a much less restrictive engine control unit. Its much more mod friendly then todays OBD2/3? ecus which are more environment friendly, Ive heard they can limit gains by sticking with stock recommendations which I'm guessing is why some people like to reset the ECU(so it thinks the mods are stock?) Well, Im sure you did free up some HP, but once you get headers, they should relieve even more pressure and you'll get even better flow.
Old 10-24-2003, 01:18 PM
Registered User
sweet, so what should i get an odb1 ecu, or a hondata ecu
Old 10-24-2003, 02:02 PM
97gsr's Avatar
97gsr 97gsr is offline
Send a message via AIM to 97gsr
that one is up to you and your budget....
if money aint a thang ... then go hondata...
if this is ur daily driver, and u just want a less restrictive ecu--
then im thinking a chipped or piggybacked(v-afc) obd1 is fine
ITR inside
