Go Back   Automotive Forums .com Car Chat > GMC > General Discussion
Old 12-15-2003, 01:16 AM   #1
webelnn
Question Is this where it goes ????????
I have an 1959 gmc 100 series plane jane base model truck and I am planning a 1985 4.3 tbi v6 swap. The motor and 3 speed auto will be donated from an 85 monte carlo that I am presently driving (to check out the mechanicals).
Having never done a tbi swap, I will need all the info I can get. I do know that the monte's puter will have to be used. As well as other sensors. My problem will be in unwirring and wirring the mess. I do plan on using after market engine and tranny crossmembers. Also I will be using a different fuel tank, don't like sittin right on top of it.
Thanks
Jim
webelnn is offline   Reply With Quote
Old 01-18-2004, 07:20 PM   #2
mdunlap13
Exclamation engine swap
This sounds like simple advice, but the most important thing to remember is to label every single wire, before you unplug it out of the monte carlo. Don't simply trust manuals and schematics. You will always find a flaw in something someone else wrote. Use colored tape to denote ground, battery hot and acc hot leads. I suggest, black red and yellow, respectively. Try to get existing harness connectors for the v6 that you can splice into the '59. This way you just need to plug it in. Meaning, Don't cut or splice on the engine side of the connector, splice or cut on the vehicle side of the connection. Marc
mdunlap13 is offline   Reply With Quote
Old 01-18-2004, 10:10 PM   #3
webelnn
Hey Mark:
I was planning to remove the entire engine compart harness with the motor and to remove all unnessary wires. Then create my own type of sensor harness. And then fashion some sort of connector and hope to get it right for the computer. If all else fails I can go to the old way and get a 4bbl. I do thank you for the info, it will help greatly.
The old girl does have her pics at geo cities. If you care to take a look at newest love. www.geocities.com/webelnn/webspicpage.html
Jim
Old 01-18-2004, 11:12 PM   #4
mdunlap13
Jim, Good luck with your swap.
Old 01-20-2004, 02:32 AM   #5
burnM
burnM's Avatar
Re: Is this where it goes ????????
Remember, "the guy who wrote the book never actually did any real work on it" at least, that's what my dad used to say...
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
burnM is offline   Reply With Quote
Old 01-22-2004, 01:52 AM   #6
webelnn
Burnm
I hear what you're saying. PROCEED WITH CAUTION!!!!LOL
Can't find where this wire goes Blaiser17 Monte Carlo 3 01-27-2008 10:04 PM
don't know where this hose goes clhuff Eclipse Problem Diagnosis 5 07-03-2007 12:49 PM
I cannot figure out where this plug goes!!! Talon69 Eclipse Problem Diagnosis 11 07-04-2006 01:58 AM
I WANT AN MR2 (question where goes the subs?) Bboy_Jon MR2/MR-S 16 12-18-2005 01:55 AM
does anybody know where this sensor goes awdpower Off-Topic 17 04-25-2005 07:53 AM
