Where is the neutral safety switch?
I have a 98 grand cherokee. The reverse lights no longer work (it is not the bulbs). I have read that the neutral safety switch can get gunked up and that the circuit to the reverse lights goes through the switch. Removing and cleaning it should fix the problem... but where is the neutral safety switch located on the 98 gr. cherokee? Diagrams/pics would be very helpful. Thanks.
Re: Where is the neutral safety switch?
It is located on the passenger side of the transmission under the veh. There is one nut to get it off.
Re: Re: Where is the neutral safety switch?
on the 42RE/42RH/46RH transmissions (I am sure it is the same for all other trannies too). The Park/Nuetral or Nuetral Safety Switch is located on the Passenger side of the transmission right above the OIL PAN the is a (I do believe) a 3 wire electrical connector.
Re: Re: Re: Where is the neutral safety switch?
CHECK OUT jeepin.com THEY HAVE A ARTICLE ON CLEANING THE NSS SWITCH HOPETHIS HELPS DALE [email protected]
I have an intermittand reverse light problem as well, but , my neutral switch is brand new , upon a trans OH.....However ..when I took the 94 GC limited to the dealer for recall upgrades , they took the center consul apart to install the brake lock safty , and evidently didnt adjust the switch in the shift colum properly , and i have intermittant reverse lights , they come on and off jiggiling the shift lever
I'm off out to have another crack at this now.. wish me luck and thanks for all your help guys.
I'm having hte same kind of problem with my 1998 grand Cherokee limited. Please could you tell me if you were able to resolved your light problem. |
[email protected]
I have the same problem on the 93 Grand Cherokee. I replaced the park neutral safety switch and it worked for a while and sure enough no reverse lights. I believe the rod on the left (driver's side) on the transmission can be adjusted for the switch. The rod goes through the transmission and through the park neutral safety switch. I haven't tried to adjust it yet, but if it works I will update
Here's a small series of photos I took of when I replace the NSS on my 89 and 90 cherokee:
http://newton.tek-ed.com/jeep/ Ed web/gadget guru Quote:
