car problems valves or something else
well guys my cars is messing up and im not sure whats wrong with it . i got a leak down test down my number2 cyclinder is low. the guy was trying to say that i need to just build my block i was like bs so now im hear my freind thinks its my valve would some bend valves cause my compression to drop in the cyclinder there bent in. the car is like missfireing and the check engine light is coming on. any help would be koo thanks
MODS: Motor :jdm b16 block, itr head, skunk 2 cam gears, msd ignition, intake, exhaust, straight pipe, skunk 2 ecu. act race clutch Suspension : grnd cntrl coilovers, 4 way adj shocks , spoon strut bar, skunk 2 sway bar, itr control arms, energy bushings misc. : super nice jdm seats, momo detachable steering wheel, Jdm clutster, Spoon Cf duckbill wing, vision smoked amber turn signals. COMING VERY SOON IN DAYS LS vtec ARP ROD BOLTS HEAD BOLTS AND 75 SHOT OF GIGLE JUICE look in my galler |
yes with a bent valve you will lose compression, and cause mis fires as well.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
if you or a friend can get to it. Pump air into the offending cylinder. Listen to the trottlebody, if you hear airflow there it's a bad intake valve. Go to the exaust pipe while pumping in the air and if you hear the air there it's prolly an exaust valve. Pop open the oil fill cap and if you hear airflow through the crankcase then your rings are bad and if you open the radiator cap and there is bubles you have a blown head gasket. This is the easiest way to check whats bad in the motor. If it be a valve the only work you have to do is head work. The block doesn't need to come out. Leave it where it is
Re: car problems valves or something else
it was 75 dollars is it to much i dont remember me said that the 2 cyl. is only getting 10 percent compression
If a valve is bent or stuck open you would have no compression.
Can't compress air and fuel in a cylinder if both valves are not closed. |
If the valve is completely jacked, then it cant have compression, but he doesnt know its broke (becuase it isnt). It wouldnt hold pressure at all, like camaro said. But if it was just a valve adjustment problem, then it could still hold some air, but let most of it out. He did say it was only 10% compressed right? Not 10% loss? Id just take off cover and check the valve lash with a feeler gague (just adjust the valves like you normally would on that cylinder (both sides)), unless your going to pay someone to do it, then I'd go through all the steps poncho mentioned before with the compressed air, before I'd pay money.
HTH Buzz1167 Jon N |
