Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 03-03-2002, 02:06 PM
Wagon4wdRTI Wagon4wdRTI is offline
Rear Disk Brake Conversion
Ok Ive seen alot of people Swapping out The Shitty Drum Brakes in
The 88-91 Honda civics now I want IN
Can I convert The Rear drums on the 88 civic Wagon 4x4 to Disk Brakes . What parts do I need If it can be done to this car, And what problems can I face doing the conversion, Is It worth the Trouble.
Im only asking Cause I need REALLY GOOD STOPPING POWER
Since Im REALLY HEAVY on The GAS. Usually When I slam on the brakes my Front wheels lock Bringing forth The 2 flat spots on the front tires, which cause vibration when im on the highway. Will Disk brakes in the rear Equal out the Braking in the front and provide Even Stopping power? Let a Fellow Ricer Know What is the Deal
If YOU CANT BEAT EM
DONT JOIN EM
JUST CHEAT! GOT NOS?
Old 03-03-2002, 04:41 PM
Ebranste Ebranste is offline
Send a message via ICQ to Ebranste Send a message via AIM to Ebranste
It will help your nose-dive problem, but not very much. You'll need a combination of replacing your shocks and struts, at least in the front as well as a rear disc conversion.
The idea is that when your car nose dives, it puts more wieght on the from end and makes it easier for you to lose traction. This causes your front brakes to lock more easily. Converting the rear to disc brakes will reduce the workload on your front brakes, but the nose dive when braking hard will still cause a loss of traction on the front end.
Costs........$200 for parts-rear disc conversion. Ask around for labor or DIYS.
New shocks and struts. $500 for parts assuming your install it yourself and aren;t looking fora sport or racing lowered suspension.
Old 03-03-2002, 06:11 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
your front brakes are what do more then 80% of your stopping, the rear brakes only come into play in emergency brakeing and when you yank the e-brake handle, other then that its all front brakes doing the work. most people do the conversion becuase it looks better and has a slight performance gain. if you wanna stop faster(sooner) then get a Big Brake Upgrade Kit from like AEM or someone, then you will notice a difference.
Stable Of Cars I have Owned:
1991 Honda CRX
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-03-2002, 09:23 PM
Your right. Your front brkaes do 80% of the work if you have rear drums, but saying that your front brakes do all the work when you press the pedal is incorrect or perhaps you are exaggerating.
Try driving a car with only front disc brakes and then say rear drums do nothing.
Also, you can't put big brakes on the font without going disc on the rear. If you do, you'll unbalance your braking system so badly, it will be as if you have no brakes on the rear at all and you're much more likely to lose control of the car when braking.
Old 08-19-2002, 06:39 AM
KiwiP10 KiwiP10 is offline
Whats needed?
What would actually be needed to do this swap? ie rotors, catapilers/pistons etc... say I could get the bits from a wreck wot else would I need?
Cheers
Old 08-20-2002, 08:36 AM
shadowboy's Avatar
shadowboy shadowboy is offline
Send a message via ICQ to shadowboy Send a message via AIM to shadowboy
resulting in understeer, which is intuitive and easy to control
Shawn
1979 Porsche 924S
1987 Honda CRX HF -- Project Chassis
1989 Acura Integra LS -- Project Parts Donor
Old 08-20-2002, 08:40 AM
shadowboy's Avatar
i am normally not like this, but
but this post is wrong, ill-informed, retarded, and incredibly so, and on so many accounts. go take a physics class. more weight on your tires means MORE traction. by your logic a FWD car should also have more traction for acceleration because the weight would shift to the rear and on a RWD car the drive wheels would lose traction. it is VERY, and i repeat VERY common knowledge that the wheels that have more weight on them, have more traction
also the brakes are biased towards the front so the front brakes CAN do more work.
also if you pay that much for your parts, you obviously do not shop around
i do not exactly know how possible this is. for starters, this is the 71-87 civic forum.. so you are posting in the wrong place to begin with.
secondly, b/c your wagon is 4WD, i do not know if you can use rear discs. if you had a normal FWD wagon you could take the rear discs off a later CRX Si, or an integra, but because of the drive axles in the rear, i am not sure how it would work.
for example, to do rear discs in the 84-87 civic you need to use quite a bit of the rear suspension of the 86-89 integra, including the rear hubs & axle. your 88-91 civic obviously won't be getting a rear axle from a 90-93 integra, but if you have to use the 90-93 integra rear hub to get the rear discs, they may not accept the rear drive axles (as the 90-93 integra was never 4wd). again, i do not know the details for i am not quite as familiar with the 88-91 civic or 90-93 integra as i am the 84-87/86-89
Shawn
1979 Porsche 924S
Old 08-20-2002, 10:57 PM
Gasoline Fumes Gasoline Fumes is offline
There's a Yahoo! Group dedicated to Civic Wagons that might be helpful.
http://groups.yahoo.com/group/hondacivicwagons/
My Website
Old 10-12-2002, 12:51 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
http://www.fourthgenhatch.com/reardiscswap.html
Thats my How-To on the rear discs. Its probably the best one you will find on the net.
However I doubt you can do it since you have rear axels and unless you someone modified the integra trailing arms to fit your axels in then it can't be done. But I think the Wagon trailing arms were unique to the Wagon only so I think you out of luck.
If you want better braking get DOT 4 Fluid, Stainless Steel Brake Lines, and good pads and rotors and that will help a lot.
Rear Discs do help in braking, after my swap its much better.
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 09-08-2003, 02:35 AM
小白 Gen3_rAcR's Avatar
小白 Gen3_rAcR 小白 Gen3_rAcR is offline
Send a message via ICQ to 小白 Gen3_rAcR Send a message via AIM to 小白 Gen3_rAcR
Re: Rear Disk Brake Conversion
hey, do you think that would work for my accord?
True skill is the key to victory. Give a terrible driver a Ferrari and a damn good driver an eclipse, and we'll see who wins.
Current Mods:
Engine:
Taylor racing wires
Bosch 4+ platinum plugs
ceramic coated exhaust headers
Carb Modifications
rebuilt motor with port/polish
Powdercoated valve cover
Exterior:
Integra GSR rims
Michelin Pilot XGT Z4 rubber
Blacked out lights (no orange)
Foglights
Interior:
Custom white/red interior
StreetGlow neon system
LED shiftknob
Reverse EL gauges
custom driver's bucket
Pioneer all through!
Plans:
custom-designed kit all around
Dropzone coilovers
either B20 engine swap w/ turbo or Gen1 Eclipse GST engine swap (damn expensive)
Streetglow Groundeffects kit
pic is a lil old...
