Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-28-2001, 02:49 PM
wikidbwoy wikidbwoy is offline
cold start problem
when it cold out side my car has trouble starting. it stays overnigth in the garage but when i try to start for the first time it tumbles but wont start. after 2 or3 times it finnaly starts. any one have any suggestions. BTW i already put a new battery in so iknow thats not the problem.:help:
Old 11-28-2001, 03:15 PM
Cyko Cyko is offline
same problem
I have the same problem with my max. I just bough a great battery and my car still doesnt do it's job. I got a remote starter and my engine is worm most of the time, but when I want to start my car from the house so it can worm up, it takes at least 2 try's . Anyone had this problem before ??? Any solutions ???
Old 11-28-2001, 03:21 PM
remote start
i can try and use my remote start when warm or cold and it wont work. i got tired of fukin with it and dont even use it any more:bonghitte
Old 11-28-2001, 04:54 PM
scholz22 scholz22 is offline
i got a 96' max and it does the same thing, it turns over fine but takes a while to fire up. anybody know what would cause this, i have abrand new battery and alternator so that isn't it. maybe it is just the engine, cuz it is alluminum
Old 11-28-2001, 05:56 PM
MegaMax MegaMax is offline
Send a message via AIM to MegaMax
Me too
I have the same Problem... I have done all normal stuff you can to it other than change the belts. I will hopefully have that done on my day off this Friday. I'll let you know if this takes care of it.
Things I have done are:
Oil Change
Plugs
Fuel Filter
Oil Filter
Injector Cleaners
Trans Oil
Coolant System Power Flushed
Battery relocated with GOLD connections to the Trunk
Note: All Fluids are Synthetic
Still on COLD days the first time it starts by or by remote it NEVER stays on the first try.
MegaMax
  • Suspension:
    Ground Control CoilOvers, $tillen FSTB, RSTB, Addco RSB
  • Lighting:
    Clear Signals, ALL bulbs Hyper White, Rewired Signals, Brighter Corner Light Mod, Rewired Fog lights, Blue Neon Headlights, Hyper White Washer Nozzles, Blue Under Car Neon, Blue Neon Under Dash, Custom wired Tail Lights
  • Cosmetic:
    Blue Break Calipers, ALL Windows Fully Tinted, NisMO badge on rear
  • Performance:
    TB Coolant Bypass, Cattman Jet-Hot Y-Pipe, High Flow Cat, Greddy Catback, $tillen HAI, Unothodox Racing Underdrive Pulley
  • Other:
    Optima Battery Relocated to Trunk,NGK Platinum Plugs, Synthetic Motor Oil (Every 5K), Synthetic Trans Fluid, 93 Octane Fuel ONLY.
  • Best E/T:
    15.4 with just the $tillen HAI 2 years ago… Now, go to the Track to find out..!
Dre's Corner
www.Maxima.Org
www.superstallions.com
www.f150online.com
Old 12-02-2001, 10:26 AM
Damn....
Well, my car doesnt start at all right now. I guess it's the starter. Could anyone tell me how much $$$ this shit will cost me ?
Old 12-02-2001, 11:00 AM
nubiannupe's Avatar
nubiannupe nubiannupe is offline
Send a message via ICQ to nubiannupe Send a message via Yahoo to nubiannupe
A decent starter shouldn't cost more than $150, I'd think. As for the starting problem, most of it may be related to the starter itself. This is just a guess on my behalf, since I went thru a similar problem, but with my last car (Nissan Sentra). Might wanna see if your starter is putting out enuff.
G. Rick (a.k.a. Tha "R") 93 Maxima SE
- PETER NORTH IS MY IDOL!!! -
81-00-65 42-54-00 93-04-97-24 (my phone# - if you figure THAT out, you can call me...) STILL GOT A BAAD ATTITUDE!!!:
Old 12-04-2001, 02:39 PM
Re: Me too
Not that it matters anymore I thought i'd post my Update...
I went to install the UDP and had a problem. (Couldn't get it off with out Air Tools) Anyway... I ended up having to put the Stock Belts back on and tighted everything back up and Presto!!! She starts on the FIRST try..!
Now all I need is to get to a Compressor to install the UDP..!!!
MegaMax
  • Suspension:
  • Lighting:
  • Cosmetic:
  • Performance:
  • Other:
  • Best E/T:
Dre's Corner
www.Maxima.Org
www.f150online.com
