got a big prob
ok my friend was hooking up his air/fuel gauge today and accidently cut the wire that runs from his o2 sensor to his ECU. When he realized this he reconnected it back and tryed to start that car. It tryed to start and back fired, now all it will do is just crank. it is getting fuel cause you can smell it, so we dont think that it's the fuel system. he also just replaced the coil, the plugs and the wires. he has also replaced the o2 sensor it's self. The car ran great before he started open the hood to install the air/fuel gauge. does any one have a clue as to what is happening. Oh yeah and the car it getting spark.
Re: got a big prob
what did he use to reconnect the wire? o2 sensor wires are shielded. i recommend using a soldering pen and heat shrink wrap.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud. |
Re: got a big prob
You have to be carefull, I soldering gun to hook mine up, as well as some heat shrink. Just like INCU said. It just sounds like your O2 might not be making good contact. Just re-wire it, or have someone do it for you.
Thats the thing he diduse solder to reconnect it. we thought the same thing at first too. but thanks for the advice any and all help is great.
Re: got a big prob
might have fried the ecu dude. A simple shock from touching it can ruin it let alone putting the solderind iron up to the wire. The current from it may have overloeaded it. Pardon me if this is wrong cuz im drunk but it seems to make sense to me... if you haev spares aroundm, try using them to see id thats the prblem. happy saint pattoes day!!!!
ZC stuff http://dh-racing.com http://www.thezcr.com/html/zcbook.php http://dmoore.com/crx/zc.htm http://www.jgenginedynamics.com/HOME%20PAGE http://www.theoldone.com/
Re: got a big prob
Its funny how he was typing fine up until he said he was drunk...then all the misspellings came out, lol.
***90 Civic EX 4 Door*** ![]() Quote:
i kept correcting them untill thenm cuz i got to lazzy, its real hard,. Anywaysm try that out man. I really think that might be the probnlem
Re: got a big prob
i agree u may have toasted the ecu. your car will start and run with no o2 hooked up to begine with.
Re: got a big prob
That is what i was affraid of. thanks alot guys we will try and get ahold of another ecu and try that.
you also mentioned that he did a tune up, plugs, wires, cap, rotor, etc.
It is possible the spark plug wires are not in the correct position on the cap. That is where your backfire would come into play. |
Check the wires, cap and stuff like that, it sounds like they may not be in correctly/in the right order. The ecu will just throw an error code for the O2 sensor, but it will run. I doubt it is the computer because they are not real sensitive to and kind of shock you could give it by fixing a wire, whereas a home computer is very sensitive.
