Go Back   Automotive Forums .com Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 10-10-2003, 11:49 AM   #1
ozzies15
max. but safe boost on silvia
hi guys, i ve just owned a 01 silvia spec r ( sr20det engine, jap. specs ) i ve hks megaflow intake, blow off valve , split fire platinium spark plugs and 8.5mm igniton wires installed. i want to increase boost but donno what will be the safest boost level on standart engine ? anyone could tell me ?? and also if a get a bleed valve or electronic boost controoler do i neet to change anything (fuel pump, injectors or other stuff ) to prevent engine damage ?? cheers
ozzies15 is offline   Reply With Quote
Old 10-14-2003, 10:51 PM   #2
J SPEC SilEighty
J SPEC SilEighty's Avatar
Send a message via AIM to J SPEC SilEighty
i hope your joking
J SPEC SilEighty is offline   Reply With Quote
Old 10-29-2003, 12:59 AM   #3
ChukBzle
I would like to know that too ozzies
ChukBzle is offline   Reply With Quote
Old 11-22-2003, 07:00 PM   #4
multilink
The SRDET's will handle around 224kw(300hp) on standard internals, I have heard that 250kw is the upper limit. The t28 & t28 rollar bearing turbos(s14a & s15) will be reliable up to 14psi, otherwise if you go over the ceramic turbine may come aprt from the turbine shaft. If the t28 ceramic is replaced the turbo will flow well up to about 15psi. It should do 19psi quite reliablebly, but will not be very effiecient & will generate quite a bit of heat. Very strong the srdet's. If you plan on turbocharging a srde(non turbo), you must change the head gastkit, pistons(lower compression from 10:00 to 8:5:1). The srdte also runs sodium cooled exuast valves & oil jets under the pistons for additional cooling.
JJ from Oz
multilink is offline   Reply With Quote
Old 11-22-2003, 07:03 PM   #5
multilink
Re: max. but safe boost on silvia
PS from JJ in Oz, I forgot that the fuel system Injectors pump/fule pressure regulator & computer will NEED to be replaced once you exceed 190-200 rear wheel KW. By the way in my last bit of jargon, all power quoted is at the rear wheels & not the flywheel.
Sorry about that.
