Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora
Old 11-02-2003, 11:38 AM   #1
Felipeu78
Question Can u fit 19" wheels on a 2001 Jetta
Hi, im new to this forum, and also Im thinking on
buying a 2000-2001 1.8 T Jetta with manual transmition.
Im just wondering if you can fit 19" wheel on it, also if I can, wot would i need, or just the rims?
thanks
Felipeu78 is offline   Reply With Quote
Old 11-02-2003, 12:13 PM   #2
Deakins
Deakins's Avatar
Re: Can u fit 19" wheels on a 2001 Jetta
Yes you can. You would need a set of 19"*8" or 19"*8.5" rims, you would also need a set of tires, 235/35-19 is recomended.
The ringing of the division bell, have stopped...
AF User Guidelines
Deakins is offline   Reply With Quote
Old 11-11-2003, 09:38 PM   #3
Felipeu78
hmm can u plz give me like the rims and tyres spec.
im really really really noob at this stuff but i wanna learn
I just saw a jetta 2001 with 45.000 miles, standard its 10.500 US dollars wot u guys think ?
Old 11-11-2003, 09:51 PM   #4
Felipeu78
like for exampe can these rims fit without any modifications to the car...
19" x 7.5"
5 Lug Rims, 5 x 100 & 5 x 4.5
:S
Old 11-12-2003, 07:19 AM   #5
Deakins
Deakins's Avatar
Re: Re: Can u fit 19
19" x 7.5"
:S
They should, but I don't recomend it.
You would end up with a load index lower than OEM with the narrow 19"*7.5" wheels. At least 19"*8" with 235/35-19 is recomended.
As for the offset and lug specs, it dependes on the wheels, but ET is probably 35mm and the lugs should be 14*1.5mm.
AF User Guidelines
Old 01-03-2004, 03:53 PM   #6
Vee Reihenmotor 6
I have a 2000 jetta vr6 and it has 18x8.5 inche wheels with 225/40 rubber. Now the 19's are a bit overkill, dont you think. Do you have any idea how high your car will sit. I have the HR cup kit which lowered the front by 2.0in and th rear by 1.7in. I have a slight tire rub on bad bumps on the road. Thing is i have a 6inch ground clearance all around. Now with 19's you'll have a 7inch or more ground clearance. The suspension i have tucks the wheels nice and 19's in my opinion would look funny. Remember this is a jetta, not some japanese car on Fast and the Furious. Be reasonable, 19's are unfunctional and with all that rotating mass youre car would be slower and your speedo will be off. Im only stating the hard facts. 18's are rare on VW's, 19's are for show cars/garage queens.
Vee Reihenmotor 6 is offline   Reply With Quote
Old 01-04-2004, 05:32 PM   #7
zackforbing
I bought my jetta a month ago... I paid $10300 for an '01 GLS, 36.5K miles, sunroof, alloys with new tires and a spoiler installed. if by "standard" you meant a GL I'd say look elsewhere.
zackforbing is offline   Reply With Quote
Old 02-18-2004, 12:18 PM   #8
layinframe_95
Send a message via MSN to layinframe_95
19's may be overkill, but thats what customizing is about...going the extra mile to stand out. Your speedo won't be off that much, and tire rub...minor set-back. If your up to it, you can re-work the inner fenders and be just fine. as for the 7 " of lift...You can always buy drop springs with more drop, or air-bags...
layinframe_95 is offline   Reply With Quote
