Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Old 06-03-2003, 01:57 AM
DaveX DaveX is offline
Question Towing limits manual vs. automatic trans
Why does the manual transmission Xterra have a lower towing limit than the automatic? Are there things I could do to tow heavier loads with my manual trans (e.g. HD clutch)? I'd think most of the powertrain must be common between these models...
Old 06-03-2003, 02:01 AM
rrdstarr's Avatar
rrdstarr rrdstarr is offline
Angry
It's the weak clutch Dave. Calmini has a HD clutch......
We don't give a damn how loud your stereo is!
Did you read your owners manual yet?
V.P. of PNWX
Old 06-03-2003, 02:50 AM
ChuckH's Avatar
ChuckH ChuckH is offline
Some would say the weak transmission too, but...
Yes, it's a clutch issue, but I believe it has more to do with Nissan trying to keep poorly skilled clutch users from frying the clutch and not being able to control the transmission than it does the actual weakness of the clutch.
The dual friction clutch really only offers more clamping power at higher revs so it may not make much difference when it comes to towing. But I'll let you know after I replace my transmission and put in a dual friction clutch...
ChuckH
Old 06-03-2003, 12:47 PM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
It's a 2-way street. Not only can 99% of the population not feather a clutch trying to get a heavy trailer going, but there's also the issue of shock loading to the driveline when the clutch does buck. An auto tranny is smooth, a manual can bite and buck and put severe loads on the gears and bearings.
Brent
Old 06-05-2003, 01:46 AM
Thanks for the responses, guys.
It sounds like for the small amount of towing I'm likely to do, I might as well just try it and see what wears. I'm mostly concerned about having no rear-facing tow points, but a friend has a #3500 boat and nothing he can pull it with, so I figured maybe I could help him out occasionally. Need some justification for a hitch other than recovery.
Now the only other problem is that I don't really like the way most of the hitches stick out, but that discussion's been had many times before.
Thanks,
DaveX
Old 06-05-2003, 03:58 AM
ChuckH's Avatar
Brent
Mine bites and bucks and has gears and bearings on their way out (you should hear it!) and I've never towed anything more than 500 lbs except other Xterras and a car for short distances. I can't even imagine how many trannies I might have gone through by now towing 5,000 lbs!
ChuckH
Old 07-21-2003, 12:31 AM
Alay510 Alay510 is offline
only 500 lbs?
i'm sure the xterra can tow (for long distances) ALOT more than 500 lbs. i assume that's either a type or you're just a very careful person.
Manual vs auto yazzagaffix Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 09-15-2009 06:45 PM
540i vs 740i. Manual vs Automatic..? swiftpete 5 Series 4 07-21-2007 05:34 PM
Want to Buy Jeep. Manual or Automatic Trans? Odublar Wrangler 8 08-24-2005 09:50 AM
6spd manual vs. Automatic Joseph1082 Camaro Discussions 78 04-08-2004 06:46 PM
manual vs automatic ???? Bob R Corvette 12 02-23-2004 02:01 PM
