Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 11-18-2001, 05:32 AM
ty423's Avatar
ty423 ty423 is offline
Send a message via AIM to ty423
Battery Relocation
I am getting ready to relocate my battery. I bought a kit and I need to run a 2 gauge wire from the engine bay to the trunk. I have a system and drilled a hole for the power line but this 2 gauge is big and don't want to make the whole any bigger. I remember reading that there is a firewall cut behind the left dust cover. Is this true? and supposedly leads next to the dead peddle.
Old 11-18-2001, 05:46 AM
p_r_i_m_e_r_a's Avatar
p_r_i_m_e_r_a p_r_i_m_e_r_a is offline
Send a message via AIM to p_r_i_m_e_r_a
Yea there is a hole large enough in the firewall, but you might try running it under the car (opposite fuel line). Another good idea is to vent your trunk if you have a venting battery.
Just an idea.
________D________
  • 94 P10 w/mods
  • 92 P10 stock
Old 11-18-2001, 04:31 PM
ty423's Avatar
What does a venting battery mean? How do you vent the trunk?
Old 11-18-2001, 11:12 PM
P10DET's Avatar
P10DET P10DET is offline
Venting means venting from the box to outside the car.
Batteries can give off hydrogen. Hydrogen can go boom. You need to vent the battery enclosure outside the car.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 11-18-2001, 11:18 PM
ty423's Avatar
OIC how do people normally do it? do they seal the box and have tubes running outside?
Old 11-19-2001, 10:16 PM
P10DET's Avatar
Yes.
George Roffe
Houston, Texas USA
00 328i
Old 11-20-2001, 02:07 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Re: Battery Relocation
I dont know if you have done it already, but i found a perfect place to do mine. When you take off the fender liner, you will see where the hood release cable goes through the firewall. I simply cut a notch in the rubber seal, ran the cable through there and sealed it back up...no water can get in and you didnt hafta drill anything, plus it makes it neat when you are running back under the carpet.
-Brian Jones
I got a snake man
Old 11-20-2001, 02:37 AM
ty423's Avatar
thanks for the tip guys
Old 11-20-2001, 03:22 AM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
an easier way to run the gauge wire to the back is through the hole where all the ecu harness come together through the firewall..that's what i did and there seem to be no problem squeezing the gauge cable through...after that, just run the cable underneath the floor carpets (not the floor matt) and you wont be able to see a thing.
Luke C.
GDA Power!
