Turn signals and headlights
I saw a new car whose driver used left turn signal. The right headlight is on and the left headlight is off while the left turn signal is blinking. I don't know the make and model of the car. It was daytime and not nighttime. Is the left headlight supposed to be on while the left turn signal is blinking?
SHO No Mo
![]() Join Date: Jun 2004
Re: Turn signals and headlights
That sounds like daytime running lights (DRLs) rather than headlights. Most newer vehicles with LED strip DRLs turn off the white LED DRL when the turn signal on that side is activated.
-Rod |
A990 racer
![]() Join Date: Mar 2002
Correct shorod, I see that on my wife's new Equinox.
Hey, I once saw a ride do the same trick. Left blinker flashing while that side headlight sat dark. In my experience, when I tap my left turn signal, both daytime running lights stay on while the indicator blinks. But I’ve learned some car models dim the DRL on the signaling side to make the blinker pop like a built-in heads-up to oncoming traffic. If it feels funky or uneven, it might be a DRL circuit hiccup or a loose bulb socket. To me, both lights should stay lit.
Lots of the newer cars do this. Normal.
Post back, that's what makes Forums Work. |
That actually sounds pretty normal for some newer vehicles. Many cars now have daytime running lights (DRLs) that double as turn signals. When the signal is activated, the DRL on that side often turns off so the blinking is more visible. So in your case, the left DRL turned off while the left turn signal blinked, and the right DRL stayed on. Totally expected behavior!
Wrenching. Learning. Enjoying the drive. Proud truck owner | Diesel fan | Always up for a good mod discussion |
#7 | ||
SHO No Mo
-Rod |
#8 | |
I guess some experimentation, with a camera phone filming such equipped cars, will confirm one way or the other.
Longacre Racing... The BEST Tire Gauges 1 AU from the Sun! |
#9 | |
It's DRL, at night the headlight does not turn off.
