Go Back   Automotive Forums .com Car Chat > GMC > Terrain
Old 07-22-2021, 11:09 AM   #1
CadillacCoupeMan
GMC Terrain
Hello,
I have a 2012 GMC Terrain 3.0 litre with 230,000 km AWD. Its been running fine, then my wife parked in front of the driveway. I rolled it back (in neutral without starting the engine) just past the driveway. The next day it refused to start and still will not start. I had a mechanic come out and do a diagnosis. He said it had power, spark, fuel pressure, fuses were good but compression was low ( he checked the front bank of cylinders .. 90-60-90 psi). He didn't do anything else.
The starter is turning, engine just won't fire.
Is the low compression the reason it doesn't start, as he said? Am I looking at engine replacement or a valve and head repair/replacement?
Thanks
CadillacCoupeMan is offline   Reply With Quote
Old 07-22-2021, 02:19 PM   #2
Stealthee
Your worst nightmare
Stealthee's Avatar
Re: GMC Terrain
I'm wondering if when you rolled it backwards you didn't cause the timing to get slack and jump time. Would explain the poor compression and no start.
Stealthee is offline   Reply With Quote
The Following 2 Users Say Thank You to Stealthee For This Useful Post:
CadillacCoupeMan (07-26-2021)
Old 07-26-2021, 02:11 PM   #3
CadillacCoupeMan
Re: GMC Terrain
Thanks Stealthee,
I don't know much about timing chains, aside from their function.
If the chain did jump, can it be reset or do you think the valves
got bent as a result of improper timing? Bearing in mind that it
never fired while I was cranking it.
Old 07-26-2021, 04:37 PM   #4
Stealthee
Stealthee's Avatar
Re: GMC Terrain
Just cranking with timing being wrong can cause bent valves on an interference engine if it is off enough.
CadillacCoupeMan (07-29-2021)
Old 08-06-2021, 12:59 PM   #5
CadillacCoupeMan
Re: GMC Terrain
Thank you Stealthee
Tags
3.0 , compression , gmc , hill , terrain
