After running fine for 15-20 minutes my alternator will begin to heat up until the point where it is too hot to even touch. As the alternator heats up the charge of the battery begins to drop until the point where the battery drains and the car dies. After sitting for enough time for the alternator to completely cool off the car will start up fine, but the process soon repeats itself.
I removed the alternator and had it tested professionally and was told that there were no indicators that pointed to it being a bad alternator. (They did not run it in the test environment for more than 2 minutes however). The leads all appear to be fine and everything is emitting the proper amps until the overheating begins. Has anyone had a problem like this or have any suggestions as to what next steps I should take? Thanks. |
Re: Overheating Alternator???
Bring it back and have them test it again (or bring it somewhere else), this time running it for however long it takes for this problem to re-occur.
I don't know how much heat an alternator should generate, but anytime the output starts to drop off, you've got a problem. Are you hearing any noise that may be the bearings going bad? |
I just bought and put in a brand new alternator. Within 20 minutes it's again too hot to touch and the battery charge begins to drop. Haven't taken it out for a long drive yet as I don't love getting stranded and waiting for a tow truck.
Do alternators generally give off heat? Any suggestions??????? This sucks... |
Anything under the hood will get somewhat hot due to the heat build-up under from the engine. However, that alone should not be causing a voltage drop.
I'm wondering if you've got a wiring problem after the alternator that is causing an excessive current draw, and causing the rectifiers in the alternator to overheat. In any event, I sure wouldn't trust this car until you've had it more thoroughly checked, because as it stands now, it will leave you stranded somewhere. PS, where/how are you measuring the voltage drop? (Just curious). |
I would test the voltage at the battery with a meter, should be around 12 V. A good test is at 1500 rpm, headlights, heater fan and radio on, should hold around 14 V. |
I have a 2001 Toyota Sienna with the same issue. I have gone through 4 alternators in a week. Did you find out what was wrong?
Did anyone find an answer ? If no-one else has solved it I think the answer may be an unusual battery fault. Try a substitute battery.
Stevef99 Brisbane |
[quote=Stevef99;7159432]Did anyone find an answer ? If no-one else has solved it I think the answer may be an unusual battery fault. Try a substitute battery.
Stevef99 Brisbane [quote] post with this is 7 years old .. I am sure it is fixed by now... |
[quote=j cAT;7159575][quote=Stevef99;7159432]Did anyone find an answer ? If no-one else has solved it I think the answer may be an unusual battery fault. Try a substitute battery.
Stevef99 Brisbane Quote:
I have the same symptoms but I do not know what the definitive answer was. It is not posted. Human nature dictates that after the original poster has worked out the solution he cannot be bothered to provide further information on the forum ~ he is too busy cruising the highway. My details are:- Everything is good from a cold start ~ 14.2 volts at the battery from the alternator, but after a few miles, the charging voltage falls lower and lower until the battery ceases to charge. I replaced the alternator but it did not make any difference. I replaced the heavy cables from the alternator to the battery. There are no wiring defects, drive belt is tight etc. A mystery, but I do not have a spare battery to try. So I was looking for the 7 year old answer. Steve Brisbane, Australia |
to begin with why did you replace your alternator?
Hi la1, It is a NEW and CURRENT problem for me. Some time back my previous alternator failed. When I took it apart, I saw that one of the diodes was dud. It looked like the entire rectifier assembly had been overheating, but I put that down to the shorted diode. My car is a 1979 V12 Jaguar. I replaced the faulty rectifier, and changed the voltage regulator. But the symptom that I described had not gone away. I dismantled the alternator again, and concluded that there may be shorted turns in one of the stator windings. I could not source a replacement stator coil, (NLA), so I had to fit a replacement alternator (later design, as original pattern alternator was obsolete) |
Thanks again for your post. A short in the door (window motor circuit) would trip the thermal cut-out, and only when the window switch is operated. Same for door lock solenoids. I will have to obtain an ammeter. I am on vacation for 5 weeks, and will not be able to post again until May. The XJ Jag wiring was designed in the sixties, so I guess we cannot expect too much.... Steve ~ Brisbane, Australia |
All these stories reminds me of Lucas Electric, prince of darkness.
