vent system 92 dodge ram van 350
On ac when accelerating or under load air is not moving through the vents but decelerating or at idle cool air abounds. Anyone know the fix. Thx MW
Re: vent system 92 dodge ram van 350
Yes, you have a vacuum leak under ood in the black plastic line that is used to pull vacuum on your mode door actuators. Under accel the engine offers very little vacuum and the doors move to their default spring loaded position which is to put air on the windshield (defrost mode) for safety reasons. When you coast, there is a much higher vacuum available in the intake manifold which now pulls the doors to there requested position (vent -panel or heat floor). So if you trace the black plastic line from your intake manifold to the vacuum reservoir, you will probably find cracked, broken or melted areas that need replaced. The check valve that hold vacuum against your mode doors may also be amiss- so check it for proper operation. I usually remove them and suck on them-- should seal one way but not the other.
This is very common issue on older vacuum operated mode doors- that use actuators. Heat from engine deteriates the plastic lines to the point they become brittle and break.
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
| The Following User Says Thank You to brcidd For This Useful Post: | ||
merrillwebb (10-17-2018)
