Old 08-28-2018, 07:56 PM   #1
jamesmetairie
98 lumina,coolant leak on floor.=
coolant on driveway floor.==
small coolant leak. passenger side nearest to fire wall area. no coolant trail seen.
a few drops on the bottom corner of engine block.
mechanic says maybe it,s coming thru the timing chain cover.
will tighten the bolts.
thanks for any advice.
jamesmetairie is offline   Reply With Quote
Old 08-28-2018, 10:25 PM   #2
Tech II
Re: 98 lumina,coolant leak on floor.=
If a coolant pressure test doesn't show the source, than add coolant dye and use a black light...
I am guessing a 3.4, and lower intakes are famous for leaking...
Old 08-28-2018, 10:27 PM   #3
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
It's possible that the TC cover is leaking. It's more probable that the corner of the intake or water pump would be a source.
Old 08-30-2018, 01:56 PM   #4
jamesmetairie
my back yard mechanic replaced the water pump about 10 days(?) ago.. it had a residue around the seep hole so we figured that was it.
the manifold gasket was replaced years ago with a metal felpro.
car has about 280,000 miles on it now.
curious thing= I,ve been having vacuum problems for a while. wonder if there,s a connection to this coolant leak somehow?
