Old 07-22-2018, 05:27 PM
jamesmetairie jamesmetairie is offline
Question a/c direction problems=--
98 base lumina, 3.1 about 275,000 miles on it.
Problem =--a/c often defaults an blows cold thur the defroster area.
My mobile mechanic is honest and highly skilled, drives a lumina and has been to Chevy factory training in Lumina days.
I bought a new vacuum resevoir ball. He tried that idea. He tested several vacuum lines and did various things all with no success. He thinks it may have something to do with one or two solinoids under the dash , behind the glove compartment.
Any idea,s will be appreciated.
It is very toasty in south Louisiana nowadays.
Old 07-23-2018, 12:41 PM
Tech II Tech II is offline
Re: a/c direction problems=--
Very simple to test the system with a hand held vacuum pump....if the actuators are vac operated...
Old 07-23-2018, 07:46 PM
Schurkey Schurkey is offline
"Defrost" is the default position for the HVAC system, because that way you're sure to have a frost-free, clear windshield.
He replaced the "ball" reservoir, but did he ever test the vacuum tubing to see if it holds vacuum? I've had multiple failures in the vacuum tubing (brittle crap) that had to be spliced with rubber vacuum hose. (This is on a '92 and 93 Lumina. I suspect but don't know for sure that the newer ones use vacuum-operated air doors rather than electronic actuators.)
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 07-24-2018, 06:49 AM
thank you to Tech II
and
thank you to Schurkey.
Old 08-28-2018, 06:24 PM
a quicky solution=
I placed a small fan on the dash blowing into my face on defrost mode.
It ain,t perfect, but it,ll do.
Occasionally try a/c or max and if it works leave it like that .
