Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 02-13-2018, 06:51 PM
Crazygirl Crazygirl is offline
Coolant reservoir problem
My daughter has an Aveo 5 LT. She recently had a coolant line blow, and we replaced it. She was still leaking coolant, and it appeared to come from the plastic reservoir tank that sits at the back of the engine compartment.
My husband thought the tank may have had a leak, so we replaced it with a new tank this last weekend. However, today my daughter noticed the reservoir is empty again, and there is more evidence of a small leak.
We have no idea where the leak could be coming from. It is isolated to the area under the reservoir platform, and it doesn't look like it is coming from either of the hoses that run from the tank area to the firewall.
She is getting frustrated, and bankrupt from buying coolant, and we are at a loss. Has anyone else had this kind of leak, or have any idea what it could be from?
Thanks!
Old 02-13-2018, 07:28 PM
Blue Bowtie's Avatar
Registered Offender
Re: Coolant reservoir problem
What model year?
Old 02-13-2018, 08:11 PM
It's a 2010
Old 02-13-2018, 09:33 PM
aleekat aleekat is offline
Get a pressure tester from local auto parts. Most have Loan a tool program to look for a leak..
Post back, that's what makes Forums Work.
Old 02-13-2018, 10:06 PM
Tech II Tech II is offline
Is it boiling out?
Old 02-14-2018, 05:54 AM
No, it's not boiling out as far as we can tell. We can just see some coolant below where the overflow reservoir is seated, and her car isn't overheating or anything.
Old 02-14-2018, 07:01 AM
rhandwor rhandwor is offline
I would check the hoses for the reservoir for a pinhole leak.
Old 02-14-2018, 10:58 AM
kenman1717 kenman1717 is offline
did you replace the pressure cap when you replaced the tank. if the evidence is under the tank or near it, it is possible the cap isn't holding its pressure and its over flowing when the car gets up to temp, and then when it cools and the level goes back down it is therefore low.
2003 Chevrolet Silverado 4.8l w/4.56 gears
2002 Chevrolet Silverado 5.3l
2001 Chevrolet Silverado 6.0l eclb
