Old 03-17-2017, 01:35 AM   #1
Muttttly
2002 Cavalier 2.2 Sfi Idle problems/Missfire 105000 KMS on car
Hello everybody been fighting this problem for months now,easier to explain what I haven't done ,only gets a code when idling for a while in closed loop,sometimes ,po 300 most of time it jumps differrent cylinders rough idle, excellerates​ without issues,Starts great,I have replaced and checked vaccum lines etc Ok what I haven't done.
Have not checked fuel pressure,crank,can,knock, sensor hasn't been changed,rear ,02 sensor not replaced and ecu not changed yet.Everything else done literally..thanks
Muttttly is offline   Reply With Quote
Old 03-17-2017, 10:29 PM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Re: 2002 Cavalier 2.2 Sfi Idle problems/Missfire 105000 KMS on car
You named it - Fuel pressure. Test that with KOEO and while running.
Old 03-27-2017, 10:49 PM   #3
Muttttly
Internal leak of the intake manifold.
In case someone reads this.
Old 03-29-2017, 07:41 AM   #4
Blue Bowtie
Registered Offender
Internal leak? Care to elaborate? I thought the intake was still aluminum in 2002.
Old 03-29-2017, 07:02 PM   #5
Muttttly
I have the 2.2 Sfi ....plastic intake manifold
Old 03-29-2017, 07:51 PM   #6
Blue Bowtie
Registered Offender
I have a '96 2.2 SFI, and it was still aluminum then. I wasn't sure when they switched.
Old 04-11-2017, 11:10 PM   #7
Muttttly
You must have a two piece manifold,As for mine yes the plastic one and it's warped causing a internal leak.
