My 02 Buick Lesabre has the dual heat and air is there away to turn it off where both sides blow the same temperature I was told I can flip a switch if this is true where is the switch located
Re: Need help asap 02 Buick Lesabre
No such switch. They use their own doors for temp control. You'll have to just set the temps the same if that's what you want.
Lets say you have your heat/air on. If you hit the off button, it beeps but stays on. When you hit it again, it goes off. That first time you hit it, puts it into a mode that makes it so the air is the same on both sides. In other words, it shuts off the ability to have the other person change the temp on there side, and puts the same temp on both sides. So yes you can, kind of. Chris.
1998 Buick Park Avenue (best car GM ever made) Buick Lesabre 1997, 191,000 152,000 - Motor R.I.P. Used 111,000 Motor, All New Gaskets Used 102,000 Transmission - SOLD New Balance 662 Trek 8000 |
