Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 10-31-2010, 12:06 PM
daybe daybe is offline
2002 malibu heater switch or fuse or relay?
My heater blower has stopped working and I am trying to figure what the issue is, 7 months ago the resistor went and I replaced that, but now it won't come on at all, looks as though a fuse may have gone as the right side of the switch isn't lite on the dash 3 through 5 settings, I have had a look at the fuses associated with the heater but can't see a problem with them, could this be one of the micro relays that has given up?
Cheers
Dave
Old 11-01-2010, 01:52 PM
rkvons's Avatar
rkvons rkvons is offline
Re: 2002 malibu heater switch or fuse or relay?
Cheers
Dave
Check to see if you have voltage at the blower motor when it is supposed to be on. The blower motor could have gone bad again. They don't make them like they used to.
Old 11-03-2010, 06:48 PM
Yep your so right rkvons,
Turns out the blower motor went bad and in turn shorted out the cluster head. The switch in the console and the fan motor had to be replaced, hoping it would have been an easy fix but never is.
Cheers
Dave
Old 11-12-2016, 12:05 PM
Scott Dog Scott Dog is offline
I changed the resister and the blower worked fine for a day or two, then no air blowing. I wiggled both harness ends to the fan motor, and resister. When I wiggled the fan motor harness end, the fan started working again.
1995 Econoline 350 relay switch?? David A Walker Econoline 2 06-30-2014 08:54 PM
AC / Heater Fan speed Switch ibkafn8ed Cherokee 0 07-05-2009 03:26 PM
Heater fan switch? Or Relay problem? 57chevyragtop Impala | Impala SS 29 03-22-2008 04:22 AM
2002 Malibu Power Locks Relay Location slee01 Malibu 2 01-23-2007 11:50 AM
1997 Malibu heater selector switch rwb22 Malibu 5 07-31-2005 05:12 PM
