Go Back   Automotive Forums Car Chat > Dodge > Caravan | Voyager
Old 09-24-2016, 10:20 PM
jehanny jehanny is offline
08 town and country smelling gasoline
Occasionally in the morning after the van has sat overnight, when my wife starts the van, she smells gasoline in the cabin. Running the A/C makes the fumes worse. Any suggestions???
Old 09-25-2016, 03:09 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 08 town and country smelling gasoline
Is it hard for her to start it meaning does it crank longer than usual until it starts? Could be the fuel rail that distributes fuel to each cylinder on top of the engine is leaking. This will leak pressure off the fuel system creating the long crank time. The fumes get sucked into the HVAC intake in front of the wipers. Get this fixed ASAP.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 09-25-2016, 04:32 PM
It is not hard to start. How do I check for a leak? Should I be concerned?
Old 09-29-2016, 08:46 PM
It's actually more often than just in the am. Is it more likely the fuel rail or injector o-rings?
Old 09-30-2016, 02:01 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
If it's not hard to start in the morning then there can't be a leak. A leak anywhere in the fuel delivery system will deplete the always present fuel pressure and make the van hard to start. It will crank an extra few seconds before it starts. This extra long cranking is the time period it takes for the pressure to build back up. I'm out of ideas.
Old 10-01-2016, 09:56 AM
If it isn't hard to start do you have any other ideas?
Old 10-01-2016, 04:26 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Turn the ignition switch to "on/run" and depress the recirculation button on the HVAC panel before turning the key to start. That will close off the air intake in front of the wipers preventing outside air from entering the cabin.
When the engine is cold it runs rich meaning more fuel is supplied to the engine to keep it running. Is it ok after the first start of the day?
Old 10-02-2016, 02:27 PM
Today it decided to sputter and stall twice while idling in park. Not sure if that changes any suggestions.
Old 10-06-2016, 07:37 AM
Nevermind...my wife just totaled the van so I don't have to troubleshoot this anymore
Old 10-11-2016, 06:55 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Wow. Hope she's ok.
Old 10-11-2016, 06:58 PM
Other than a sore back I think she's OK. She did get a brand-new Pacifica out of the deal so I think she's happy.
