| Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
Carburetor Issues
Hello everyone, I recently bought this Plymouth Fury II with a couple issues. Most of which was very hard idling and and upon accelerator engine would die out. Both of these issues were diagnosed to be direct results of a faulty carburetor. Being a beginner mechanic I decided I would take it upon myself to rebuild it as my first act as a mechanic. The process went smooth, everything was cleaned, reassembled correctly, new gaskets, and installed. I was able to get the car back running again but now I have another problem. The choke plate does not seem to be functioning as it should anymore. In other words it only moves when I reach in there and move it myself, and it stays where I leave it. The rods on both sides of the choke are correctly connected to it, but nothing is acting upon those rods. It's difficult to explain so I'll include pictures. But it just seems like there supposed to be some sort of pressure being applied to the plate to keep it open/closed so the carburetor works correctly.
If you have any questions on my explanation please comment and help me with this situation I've had this car sitting in my driveway for way to long now.The item circled in the first 2 pictures moves freely via gravity. Nothing is acting upon it. It looks just as it did when I took it off so I am hoping someone knows what happened. |
A990 racer
![]() Join Date: Mar 2002
Re: Carburetor Issues
Disconnect the rod from the choke stove, see if it has spring pressure to close the choke when cold. This is the only thing that controls the choke plate other than the vacuum pull of diaphragm.
There is no pressure being applied to it at all. I was thinking that the spring/coil was the problem but I didn't touch it upon reassembly. When I dissambeled it I set that rod, coil, and cover aside as a whole. Is the spring just coincidentally worn out?
A990 racer
If the choke has no cold tension, something is wrong with it obviously, take it off and see what's what.
I'm going to be honest here guys, I'm not sure what I did to fix it, but I was able to get it working. I disconnected the coil rod from the side of the carburetor, and removed the coil, rod, and cover to inspect it closer. I did not see anything out the ordinary so I just put it back on. Upon replacing it, it is now holding tension. Looks exactly the same as it did before. It's quite possible that I just had it twisted or placed oddly enough for it to not work anymore. Maybe the coil was pressed upside down and upon removing it, it was able to stand upright again. Thanks for the advice though
