AC blows hot air except in Max AC
This is a future reference/tutorial post:
This problem is usually due to a bad blend door actuator. The Max AC setting bypasses the blend door, and when the actuator is broken, air pressure from the fan can move the door to the max heat position. Sometimes the actuator will just stick in one position, and so adjusting the temp dial will do nothing. Here is a video outlining the location, removal and installation of the actuator. This guy makes it look easy; getting the actuator in and out is pretty difficult and time-consuming. Also, the actuator post may not be in the right position for getting it installed into the blend door socket. If this happens, then you will want to reattach the environmental control panel (I removed it from the dash and plugged it in; did not have to hook up the vacuum lines), plug the actuator in, and turn on the vehicle (accessory will work, you don't have to start the engine). Adjusting the temperature control will cause the actuator post to turn to a different position. I had to do this, and then ended up with the actuator partially inserted, but the blend door was pegged to the cold position and I couldn’t get the actuator placed, so I had to reconnect the cable and reposition the post again so that I could finish installing. It took me forty minutes with an assistant and a pair of chopsticks to get this connector reinstalled, so if you have to move the actuator post, don't disconnect it until you are done, if you can help it.
2003 Ford Expedition 4.6L (Dngrswife's) 2006 Kia Sedona 2008 Toyota Prius (totaled) 1997 Windstar 3.8 liter (retired) Replaced Head Gaskets 1988 S-10 2.8 liter (retired) Full Rebuild |
Re: AC blows hot air except in Max AC
Brian's youtube videos are so helpful. When he started he would post the references in this forum. Now with him in business for himself he doesn't have the time to do that, so it is up to us to reference them when we can.
